system services firewall policy modify
PDF of this doc site
Creating your file...
Modify a firewall policy entry for a network service
The system services firewall modify command enables you to modify the list of IP addresses and netmasks associated with a firewall policy.
-vserver <vserver>
- Vserver Name-
Use this parameter to specify the Vserver of the policy to modify.
-policy <textpolicy_name>
- Policy-
Use this parameter to specify the name of the policy to modify.
-service <service>
- Service-
Use this parameter to specify the policy’s network service to modify.
[-allow-list <IP Address/Mask>,…]
- Allowed IPs-
Use this parameter to specify one or more IP addresses with corresponding netmasks that are allowed by this firewall policy. The correct format for this parameter is address/netmask, similar to "192.0.2.128/25". Multiple address/netmask pairs should be separated with commas. Use the value
0.0.0.0/0
for "any".
The following example modifies the firewall policy named data that uses the SSH protocol to enable access from all addresses on the 192.0.2.128 subnet:
cluster1::> system services firewall policy modify -policy data -service ssh -allow-list 192.0.2.128/25
