vserver fpolicy prepare-to-downgrade
Restore the FPolicy configuration to Earlier Release of Data ONTAP
The vserver fpolicy prepare-to-downgrade command restores the FPolicy configurations for Data ONTAP based on the input parameter disable-feature-set.
-disable-feature-set <downgrade version>- Data ONTAP Version (privilege: advanced)-
This parameter specifies the Data ONTAP version that introduced the new FPolicy features and needs to be restored. The value can be one of the following:
9.0.0 - Disables the FPolicy features introduced in Data ONTAP release 9.0.0. These features include:
FPolicy filters for setattr operation.
FPolicy filter
exclude-directoryfor directory operations. -
FPolicy Async Resiliency feature.
FPolicy "Monitor Objects With No Extension" feature.
cluster1::*> vserver fpolicy prepare-to-downgrade -disable-feature-set 9.0.0
