vserver fcp ping-igroup show
Ping FCP by Igroup
This command performs a connectivity check (ping) between the FCP initiators of an igroup and the FCP LIFs for which they are configured.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to select the Vservers that contain initiators and FCP LIFs.
[-igroup <text>] - Igroup Name
Use this parameter to select the FCP initiators that belong to the specified igroup and FCP LIFs that belong to the portset that is bound to the igroup. If the igroup is not bound to a portset, then the default portset (all FCP LIFs in the Vserver), is used.
[-wwpn <text>] - FCP initiator WWPN
Use this parameter to select the FCP initiator WWPN.
[-lif <text>] - LIF Name
Use this parameter to limit the test to a subset of the FCP LIFs available for the igroup.
[-portset <text>] - Portset
Use this parameter to select igroups bound to the specified portset.
[-node <nodename>] - Node
Use this parameter to select the nodes that contain the specified FCP LIFs.
[-status {unknown|reachable|not-reachable|not-zoned|cannot-ping-same-wwpn|fcp-service-busy|lif-is-down|zone-info-not-available}] - Ping Status
Use this parameter to select the status of FCP ping command.
[-ext-status {logged-in|not-logged_in|not-in-fabric|not-in-same-zone|fabric-info-not-available}] - Extended Status
Use this parameter to select the extended status of FCP ping command.
[-check-fabric <true>] - Query Fabric Records
Use this parameter to query the unzoned name server for the FCP initiator WWPN.
cluster1::> vserver fcp ping-igroup show
          Igroup                     Node       Logical   Ping       Extended
Vserver   Name        WWPN           Name       Interface Status     Status
vserver_1
          igroup_1    c0:03:ff:e4:70:06:00:e4
                                     node_1
                                                lif_1     reachable  wwpn-logged-in
          igroup_1    c0:03:ff:e4:70:06:00:e6
                                     node_2
                                                lif_2     not-zoned  -
2 entries were displayed.
