storage disk option show
Display a list of disk options
The storage disk option show
command displays the settings of the following disk options:
Background firmware update
Automatic copying of data to a spare disk in the event of a predictive failure
Automatic assignment of disks
Policy that governs automatic assignment of unowned disks
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the node that owns the disks. If this parameter is not specified, the command displays information about the disk options on all the nodes.
[-bkg-firmware-update {on|off}]
- Background Firmware Update-
Selects the disks that match this parameter value.
[-autocopy {on|off}]
- Auto Copy-
[-autoassign {on|off}]
- Auto Assign-
Displays the auto assignment status of unowned disks. The default value is
on
. [-autoassign-policy {default|bay|shelf|stack}]
- Auto Assignment Policy-
Selects the disks that match the automatic assignment policy value:
Default
Stack/loop
Shelf
Bay
The following example displays disk-option settings for disks owned by all nodes in the cluster:
cluster1::> storage disk option show Node BKg. FW. Upd. Auto Copy Auto Assign Auto Assign Policy ------------- ------------- ------------ ------------- ------------------ node0 on on on default node1 on on on stack node2 on on on bay node3 on on on bay 4 entries were displayed.
