ONTAP commands
system services manager policy setstate
Enable/disable a service policy
The system services manager policy setstate command enables or disables services manager policies. Use the system services manager policy show command to display information about configured policies.
-service <text> - Service
Use this parameter to set the state of the policy you specify.
-version <service version> - Version
Use this parameter to set the state of the policy with the version number you specify.
-state {on|off} - State
Use this parameter with the value "on" to enable the policy. Use this parameter with the value "off" to disable the policy.
The following example sets the policy for version 1.0 of the diagnosis service to off.
cluster1::> system services manager policy setstate -service diagnosis -version 1.0 -state off
