vserver export-policy config-checker rule show
Show error entries for rules in export policy configuration checker job
The vserver export-policy config-checker rule show command displays information about error related to configuration in export policy rules. If a rule has any issues the configuration checker job will log information about such errors on the node where the job runs. The command displays the following information:
Node name
Vserver name
Export policy name
Export policy rule index number
Export policy rule error
- { [-fields <fieldname>,…]
If you specify the -fieldsparameter, the command only displays the fields that you specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all entries.
- [-node {<nodename>|local}]- Node
If you specify this parameter, the command displays detailed error information for node that matches the specified value.
- [-vserver <vserver name>]- Vserver
If you specify this parameter, the command displays detailed error information for Vservers that match the specified value.
- [-policy <export policy name>]- Policy Name
If you specify this parameter, the command displays detailed error information for policy that match the specified value.
- [-rule-index <integer>]- Rule Index
If you specify this parameter, the command displays detailed error information for rule-index that match the specified value.
- [-error <text>]- Error Details
If you specify this parameter, the command displays rule index information for error that match the specified value. The complete error string needs to be specified within "{}".
The following example displays information about error related to export rules:
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test
  (vserver export-policy config-checker rule show)
                        Rule
Node       Vserver      Policy    Index     Error
node-vsim3
           vs34         test      1         DNS lookup for host "h1" failed
           vs34         test      2         Entry not found for "UserName: testuser", DNS lookup for host "h2" failed
2 entries were displayed.
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test -rule-index 1
Node: node-vsim3
      Vserver: vs34
  Policy Name: test
   Rule Index: 1
Error Details: DNS lookup for host "h1" failed
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test -error  {DNS lookup for host "h1" failed}
                        Rule
node-vsim3
 PDFs
PDFs
