vserver export-policy config-checker rule show
Show error entries for rules in export policy configuration checker job
The vserver export-policy config-checker rule show command displays information about error related to configuration in export policy rules. If a rule has any issues the configuration checker job will log information about such errors on the node where the job runs. The command displays the following information:
Node name
Vserver name
Export policy name
Export policy rule index number
Export policy rule error
[-fields <fieldname>,…] -
If you specify the
-fieldsparameter, the command only displays the fields that you specify. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all entries. [-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays detailed error information for node that matches the specified value.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays detailed error information for Vservers that match the specified value.
[-policy <export policy name>]- Policy Name-
If you specify this parameter, the command displays detailed error information for policy that match the specified value.
[-rule-index <integer>]- Rule Index-
If you specify this parameter, the command displays detailed error information for rule-index that match the specified value.
[-error <text>]- Error Details-
If you specify this parameter, the command displays rule index information for error that match the specified value. The complete error string needs to be specified within "{}".
The following example displays information about error related to export rules:
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test
(vserver export-policy config-checker rule show)
Rule
Node Vserver Policy Index Error
node-vsim3
vs34 test 1 DNS lookup for host "h1" failed
vs34 test 2 Entry not found for "UserName: testuser", DNS lookup for host "h2" failed
2 entries were displayed.
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test -rule-index 1
Node: node-vsim3
Vserver: vs34
Policy Name: test
Rule Index: 1
Error Details: DNS lookup for host "h1" failed
cluster1::> vserver export-policy config-checker rule show -node node-vsim3 -vserver vs34 -policy test -error {DNS lookup for host "h1" failed}
Rule
node-vsim3
