ONTAP 9.3 commands
storage aggregate reallocation show
Show reallocate job status for improving free space layout
Displays the status of a reallocation scan, including the state, schedule, aggregate and scan id. If you do not specify the id for a particular reallocation scan, the command displays information about all the existing reallocation scans.
{ [-fields <fieldname>,…​]
Displays the value of relevant field that you specify for the reallocation scans that are present.
| [-v ]
Specify this parameter to display the output in a verbose format.
| [-instance ] }
Displays information about reallocation scans on aggregates in a list format.
[-id <integer>] - Job ID
Specify this parameter to display the reallocation scan that matches the reallocation job ID that you specify.
[-aggregate <aggregate name>] - Aggregate Name
Specify this parameter to display the reallocation scan that matches the aggregate that you specify.
[-description <text>] - Job Description
Specify this parameter to display reallocation scans that match the text description that you specify.
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - Job State
Specify this parameter to display reallocation jobs that match the state that you specify.
[-progress <text>] - Execution Progress
Specify this parameter to list the running reallocation jobs whose progress indicator matches the text that you provide. For example, if you specify "Starting …​" as the text string for the progress option, then the system lists all the jobs that are starting.
[-schedule <job_schedule>] - Schedule Name
Specify this parameter to display reallocation scans that match the schedule name that you specify. If you want a list of all job schedules, use the job schedule show command.
[-global-status <text>] - Global State of Scans
Specify this parameter to indicate if reallocation scans are on or off globally. You must type either of the following text strings:
  • "Reallocation scans are on"
  • "Reallocation scans are off"
cluster1::> storage aggregate reallocation show
Job ID            Aggregate               Schedule                State
23                aggr0                   reallocate_0 23 * 6     Queued
Displays the job ID, aggregate, schedule, and state for the reallocation scans.
