system service-processor network auto-configuration enable
PDF of this doc site
Creating your file...
Enable Service Processor Auto-Configuration
The system service-processor network auto-configuration enable
command enables the automatic network configuration for the SP. This is a cluster-wide configuration. Every node in the cluster will use the specified subnet to allocate IP address, subnet mask and gateway address for the SP configuration. When the SP automatic network configuration is enabled, you do not need to manually manage the SP network of individual nodes. A node that subsequently joins the cluster uses the specified subnet to configure its SP network automatically.
Prior to running this command, the subnet you want to use for the SP automatic network configuration must already be defined in the cluster and must have no resource conflicts with the SP network interface.
-address-family {IPv4|IPv6}
- Subnet Address Family-
This parameter specifies whether the IPv4 or the IPv6 automatic configuration is to be enabled for the SP.
-subnet-name <text>
- Subnet Name-
This parameter specifies the network subnet that the SP will use for automatic network configuration.
The following example enables the automatic network configuration for IPv4 on the SP. It first displays the current SP network configuration, displays available network subnet in the cluster, and then enable the SP to use the subnet for IPv4 automatic configuration.
cluster1::>system service-processor network show Address Node Status Family Link State IP Address ------------- -------------- --------- ----------- ------------------------ node1 online IPv4 up 192.168.1.201 DHCP: v4 MAC Address: ab:cd:ef:fe:ed:01 Network Gateway: 192.168.1.1 Network Mask (IPv4 only): 255.255.255.0 Prefix Length (IPv6 only): - IPv6 RA Enabled: - Subnet Name: - SP Network Setup Status: succeeded
cluster1::> network subnet show IPspace: Default Subnet Broadcast Avail/ Name Subnet Domain Gateway Total Ranges --------- ---------------- --------- --------------- --------- --------------- ipv4_test 192.168.1.0/24 Default 192.168.1.1 3/5 192.168.1.2-192.168.1.6
cluster1::>system service-processor network auto-configuration enable -address-family ipv4 -subnet-name ipv4_test cluster1::system service-processor network> show Address Node Status Family Link State IP Address ------------- -------------- --------- ----------- ------------------------ node1 online IPv4 up 192.168.1.2 DHCP: none MAC Address: ab:cd:ef:fe:ed:01 Network Gateway: 192.168.1.1 Network Mask (IPv4 only): 255.255.255.0 Prefix Length (IPv6 only): - IPv6 RA Enabled: - Subnet Name: ipv4_test SP Network Setup Status: succeeded
