Command reference
system service-processor network auto-configuration enable
Enable Service Processor Auto-Configuration
The system service-processor network auto-configuration enable command enables the automatic network configuration for the SP. This is a cluster-wide configuration. Every node in the cluster will use the specified subnet to allocate IP address, subnet mask and gateway address for the SP configuration. When the SP automatic network configuration is enabled, you do not need to manually manage the SP network of individual nodes. A node that subsequently joins the cluster uses the specified subnet to configure its SP network automatically.
Prior to running this command, the subnet you want to use for the SP automatic network configuration must already be defined in the cluster and must have no resource conflicts with the SP network interface.
-address-family {IPv4|IPv6} - Subnet Address Family
This parameter specifies whether the IPv4 or the IPv6 automatic configuration is to be enabled for the SP.
-subnet-name <text> - Subnet Name
This parameter specifies the network subnet that the SP will use for automatic network configuration.
The following example enables the automatic network configuration for IPv4 on the SP. It first displays the current SP network configuration, displays available network subnet in the cluster, and then enable the SP to use the subnet for IPv4 automatic configuration.
cluster1::>system service-processor network show
                             Address
Node          Status         Family    Link State  IP Address
node1
              online         IPv4      up          192.168.1.201
DHCP: v4
                          MAC Address: ab:cd:ef:fe:ed:01
                      Network Gateway: 192.168.1.1
             Network Mask (IPv4 only): 255.255.255.0
            Prefix Length (IPv6 only): -
                      IPv6 RA Enabled: -
                          Subnet Name: -
              SP Network Setup Status: succeeded
cluster1::> network subnet show
IPspace: Default
Subnet                     Broadcast                   Avail/
Name      Subnet           Domain    Gateway           Total   Ranges
ipv4_test 192.168.1.0/24  Default   192.168.1.1       3/5    192.168.1.2-192.168.1.6
cluster1::>system service-processor network auto-configuration enable -address-family ipv4 -subnet-name ipv4_test
cluster1::system service-processor network> show
                             Address
node1
DHCP: none
                      IPv6 RA Enabled: -
                          Subnet Name: ipv4_test
