lun igroup unbind
Unbind an existing initiator group from a portset
This command unbinds an initiator group from a port set. When you unbind an initiator group from a port set, all of the initiators in the initiator group have access to all target LUNs on all network interfaces.
This command is not supported for a Vserver with Infinite Volume. |
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
-igroup <text>- Igroup Name-
Specifies the initiator group that you want to unbind from the port set.
cluster1::> lun igroup unbind -vserver vs1 -igroup ig1
Unbinds the initiator group ig1 from the port set on Vserver vs1.
