security config ocsp disable
Disable OCSP for one or more selected applications
The security config ocsp disable command disables the OCSP-based certificate status check for applications supporting SSL/TLS communications. For more information about the OCSP-based certificate status check for applications supporting SSL/TLS communications, see the security config ocsp show command.
-application <Application supporting SSL/TLS protocol>,…​ - Application Name
Use this parameter to specify the application to disable the OCSP support. To disable all applications, the value 'all' can be used. Note: You cannot specify the value 'all' with other applications.
The following example disables the OCSP support for AutoSupport and EMS applications:
cluster1::*> security config ocsp disable -application autosupport,ems
cluster1::> security config ocsp show
Application          OCSP Enabled?
autosupport          false
audit_log            true
fabricpool           true
ems                  false
kmip                 true
ldap                 true
6 entries were displayed.
The following example disables the OCSP support for all applications:
cluster1::*> security config ocsp disable -application all
Warning: OCSP will be disabled for all applications. Any previous modifications
         will be ignored.
         Do you want to continue? {y|n}: y
cluster1::*> security config ocsp show
autosupport          false
audit_log            false
fabricpool           false
ems                  false
kmip                 false
ldap                 false
