vserver cifs domain trusts rediscover
PDF of this doc site
Creating your file...
Your file is ready
Reset and rediscover trusted domains for a Vserver
The vserver cifs domain trusts rediscover
command discards information the Vserver has stored about trusted domains. After that, it begins the discovery process to reacquire current information about trusted domains. This command is not supported for workgroup CIFS servers.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver.
The following example rediscovers trusted domains. It produces no output.
cluster1::> vserver cifs domain trusts rediscover
