vserver cifs share access-control create
- PDF of this doc site
Creating your file...
Your file is ready
Create an access control list
The vserver cifs share access-control create
command adds a user or group to a CIFS share's ACL.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver containing the CIFS share.
-share <Share>
- Share Name-
This parameter specifies the name of the CIFS share.
-user-or-group <TextNoCase>
- User/Group Name-
This parameter specifies the user or group to add to the CIFS share's access control list. If you specify the user name, you must include the user's domain using the format "domain\username". The user-or-group parameter is case-insensitive text.
[-user-group-type {windows|unix-user|unix-group}]
- User or Group Type-
This
