storage aggregate object-store config show
Display a list of object store configurations
The storage aggregate object-store config show command displays information about all existing object store configurations in the cluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-object-store-name <text>]- Object Store Configuration Name
If this parameter is specified, the command displays information only about object store configurations whose name matches the specified names.
- [-object-store-uuid <UUID>]- UUID of the Object Store Configuration
If this parameter is specified, the command displays information only about object store configurations whose UUID matches the specified UUID values.
- [-provider-type <providerType>]- Type of the Object Store Provider
If this parameter is specified, the command displays information only about object store configurations whose provider type matches the specified value.
- [-server <Remote InetAddress>]- Fully Qualified Domain Name of the Object Store Server
If this parameter is specified, the command displays information only about object store configurations whose server name matches the specified value. The server name is specified as a Fully Qualified Domain Name (FQDN).
- [-ssl-enabled {true|false}]- SSL/HTTPS Enabled?
If this parameter is specified, the command displays information only about object store configurations whose status about the use of secured communication over the network (for example, SSL certificates) matches the specified value.
- [-port <integer>]- Port Number of the Object Store
If this parameter is specified, the command displays information only about object store configurations whose port numbers matches the specified value.
- [-container-name <text>]- Data Bucket/Container Name Used in S3 Requests
If this parameter is specified, the command displays information only about object store configurations whose container name matches the specified value. Data ONTAP uses this container name or object store data bucket while accessing data from the object store.
- [-access-key <text>]- Access Key
If this parameter is specified, the command displays information only about object store configurations whose access key matches the specified value. Data ONTAP requires the access key for authorized access to the object store.
- [-ipspace <IPspace>]- IPspace to Use in Order to Reach the Object Store
If this parameter is specified, the command displays information only about object store configurations whose IPspace matches the specified value. Data ONTAP uses the IPspace value to connect to the object store.
- [-use-iam-role {true|false}]- Use IAM Role for AWS ONTAP Cloud
If this parameter is specified, the command displays information only about object store configurations whose IAM role status flag matches the specified value. The -iam-roleand `-use-iam-role ` parameters are relevant only in the context of AWS object store and indicates whether IAM role must be used for accessing it. The IAM credentials can be obtained only through AWS Data ONTAP Cloud.
- [-iam-role <text>]- IAM Role for AWS ONTAP Cloud
If this parameter is specified, the command displays information only about object store configurations whose IAM (Identity and Access Management) role matches the specified value.
The following example displays all available object store configuration in the cluster:
cluster1::>storage aggregate object-store config show
 PDFs
PDFs
