network test-link stop-server
PDF of this doc site
Creating your file...
Your file is ready
Stop server for bandwidth test
The network test-link stop-server
command stops the network test-link
server running on the designated node.
-node {<nodename>|local}
- Node Name-
Use this parameter to specify the node where the server is to be stopped.
The following example starts a server and stops it:
cluster1::*> network test-link start-server -node node1 cluster1::*> network test-link stop-server -node node1
