ONTAP commands
security certificate ca-issued show
Display CA-Issued Digital Certificates
This command displays the following information about the digital certificates issued by the self-signed root-ca:
  • Vserver
  • Serial number of certificate
  • FQDN or custom common name or the name of a person
  • Serial number of CA certificate
  • Status (active, revoked )
  • Certificate Authority
  • Expiration date
  • Revocation date
To display more details, run the command with the -instance parameter. This will add the following information:
  • Country name
  • State or province name
  • Locality name
  • Organization name
  • Organization unit
  • Contact administrator's email address
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Selects the certificates that match this parameter value.
[-serial <text>] - Serial Number of Certificate
[-ca <text>] - Certificate Authority
[-ca-serial <text>] - Serial Number of CA Certificate
[-common-name <FQDN or Custom Common Name>] - FQDN or Custom Common Name
[-status <status of certificate>] - Status of Certificate
Selects the certificates that match this parameter value. Possible values include active and revoked.
[-expiration <Date>] - Certificate Expiration Date
[-revocation <Date>] - Certificate Revocation Date
[-country <text>] - Country Name (2 letter code)
[-state <text>] - State or Province Name (full name)
[-locality <text>] - Locality Name (e.g. city)
[-organization <text>] - Organization Name (e.g. company)
[-unit <text>] - Organization Unit (e.g. section)
[-email-addr <mail address>] - Email Address (Contact Name)
The examples below display information about CA issued digital certificates.
cluster1::> security certificate ca-issued show
Serial Number of
Vserver    Serial Number   Common Name                 CA's Certificate Status
vs0        4F5A2C90         example.com                  4F4EB629         active
    Certificate Authority: vs0.cert
          Expiration Date: Sat Apr 14 16:15:13 2012
          Revocation Date: -
vs0        4F5A2DF2         example.com                  4F4EB629         revoked
          Expiration Date: Sat Apr 14 16:21:06 2012
          Revocation Date: Fri Mar 09 17:08:30 2012
2 entries were displayed.
cluster1::> security certificate ca-issued show -instance
Vserver: vs0
         Serial Number of Certificate: 4F5A2C90
      Serial Number of CA Certificate: 4F4EB629
           FQDN or Custom Common Name:  example.com
                Status of Certificate: active
          Certificate Expiration Date: Sat Apr 14 16:15:13 2012
          Certificate Revocation Date: -
         Country Name (2 letter code): US
   State or Province Name (full name): California
            Locality Name (e.g. city): Sunnyvale
     Organization Name (e.g. company): example
     Organization Unit (e.g. section): IT
         Email Address (Contact Name):  web@example.com
