ONTAP 9.3 commands
volume efficiency policy delete
Delete an efficiency policy
The volume efficiency policy delete command deletes an efficiency policy. An efficiency policy can be deleted only when it is not associated with any volume. The pre-defined policies default and inline-only cannot be deleted.
-vserver <vserver name> - Vserver
This specifies the Vserver on which the volume is located.
-policy <text> - Efficiency Policy Name
This specifies the policy name.
The following example deletes an efficiency policy:
cluster1::> volume efficiency policy delete -vserver vs1 -policy policy1
