The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume efficiency policy delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an efficiency policy
The volume efficiency policy delete
command deletes an efficiency policy. An efficiency policy can be deleted only when it is not associated with any volume. The pre-defined policies default
and inline-only
cannot be deleted.
-vserver <vserver name>
- Vserver-
This specifies the Vserver on which the volume is located.
-policy <text>
- Efficiency Policy Name-
This specifies the policy name.
The following example deletes an efficiency policy:
cluster1::> volume efficiency policy delete -vserver vs1 -policy policy1
