system services firewall policy show
PDF of this doc site
Creating your file...
Show firewall policies
The system services firewall policy show
command displays information about firewall policies.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
Use this parameter to display all the fields for the specified policies.
[-vserver <vserver>]
- Vserver Name-
Use this parameter to display information only about the Vserver you specify.
[-policy <textpolicy_name>]
- Policy-
Use this parameter to display information about the policy you specify.
[-service <service>]
- Service-
Use this parameter to display information about the services you specify.
[-allow-list <IP Address/Mask>,…]
- Allowed IPs-
Use this parameter to display information about the firewall policies that match the list of allowed IP addresses and netmasks you specify. The correct format for this parameter is address/netmask, similar to "192.0.2.128/25". Multiple address/netmask pairs should be separated with commas.
[-ipspace <text>]
- IPspace-
Use this parameter to display information only about the IPspace you specify.
The following example displays information about all firewall policies:
cluster1::> system services firewall policy show Vserver Policy Service Allowed ------- ------------ ---------- ------------------- cluster1 data dns 0.0.0.0/0, ::/0 ndmp 0.0.0.0/0, ::/0 ndmps 0.0.0.0/0, ::/0 cluster1 intercluster ndmp 0.0.0.0/0, ::/0 ndmps 0.0.0.0/0, ::/0 cluster1 mgmt dns 0.0.0.0/0, ::/0 http 0.0.0.0/0, ::/0 https 0.0.0.0/0, ::/0 ndmp 0.0.0.0/0, ::/0 ndmps 0.0.0.0/0, ::/0 ntp 0.0.0.0/0, ::/0 snmp 0.0.0.0/0, ::/0 ssh 0.0.0.0/0, ::/0
