ONTAP commands
system services firewall policy show
Show firewall policies
The system services firewall policy show command displays information about firewall policies.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
Use this parameter to display all the fields for the specified policies.
[-vserver <vserver>] - Vserver Name
Use this parameter to display information only about the Vserver you specify.
[-policy <textpolicy_name>] - Policy
Use this parameter to display information about the policy you specify.
[-service <service>] - Service
Use this parameter to display information about the services you specify.
[-allow-list <IP Address/Mask>,…​] - Allowed IPs
Use this parameter to display information about the firewall policies that match the list of allowed IP addresses and netmasks you specify. The correct format for this parameter is address/netmask, similar to "192.0.2.128/25". Multiple address/netmask pairs should be separated with commas.
[-ipspace <text>] - IPspace
Use this parameter to display information only about the IPspace you specify.
The following example displays information about all firewall policies:
cluster1::> system services firewall policy show
Vserver Policy       Service    Allowed
cluster1
        data
                     dns        0.0.0.0/0, ::/0
                     ndmp       0.0.0.0/0, ::/0
                     ndmps      0.0.0.0/0, ::/0
cluster1
        intercluster
cluster1
        mgmt
                     dns        0.0.0.0/0, ::/0
                     http       0.0.0.0/0, ::/0
                     ntp        0.0.0.0/0, ::/0
                     snmp       0.0.0.0/0, ::/0
cluster1
        mgmt-nfs
                     dns        0.0.0.0/0, ::/0
                     ntp        0.0.0.0/0, ::/0
17 entries were displayed.
cluster1::>
