cluster log-forwarding modify
Modify log forwarding destination settings
The cluster log-forwarding modify command modifies log forwarding destinations for remote logging.
-destination <Remote InetAddress> - Destination Host
The host name or IPv4 or IPv6 address of the server to be modified.
-port <integer> - Destination Port
The port that the destinations servers listen on.
[-verify-server {true|false}] - Verify Destination Server Identity
When this parameter is set to true , the identity of the log forwarding destination is verified by validating its certificate. The value can be set to true only when the tcp-encrypted value is selected in the protocol field. When this value is true the remote server might be validated by OCSP. The OCSP validation for cluster logs is controlled with the security config ocsp enable -app audit_log and security config ocsp disable -app audit_log .
[-facility <Syslog Facility>] - Syslog Facility
The syslog facility to use for the forwarded logs.
This example modifies the facility of audit logs that are forwarded to the destination server at address 192.168.0.1, port 514.
cluster1::> cluster log-forwarding modify -destination 192.168.0.1 -port 514 -facility local1
