vserver services ndmp probe
Display list of NDMP sessions
The system services ndmp probe command displays diagnostic information about NDMP sessions belonging to a specific Vserver in the cluster. The following fields are displayed for each of the sessions:
Vserver
Session identifier
NDMP version
Session authorized
Data state
Data operation
Data server halt reason
Data server connect type
Data server connect address
Data server connect port
Data bytes processed
Mover state
Mover mode
Mover pause reason
Mover halt reason
Mover record size
Mover record number
Mover bytes moved
Mover seek position
Mover bytes left to read
Mover window offset
Mover window length
Mover position
Mover SetRecordSize flag
Mover SetWindow flag
Mover connect type
Mover connect address
Mover connect port
Effective host
NDMP client address
NDMP client port
SCSI device ID
SCSI hostadapter
SCSI target ID
SCSI LUN ID
Tape device
Tape mode
Node
Is Secure Control Connection
Data Backup Mode
Data Path
NDMP Source Address
[-vserver <vserver name>]
- Vserver-
This parameter Specifies the Vserver context in which NDMP sessions are running.
[-session-id <text>]
- Session Identifier-
If this parameter is specified, the command displays information about a specific NDMP session. A session-id is a string used to identify a particular NDMP session.
[-ndmp-version <integer>]
- NDMP Version-
This parameter refers to the NDMP protocol version being used in the session.
[-session-authorized {true|false}]
- Session Authorized-
This parameter indicates whether an NDMP session is authenticated or not.
[-data-state <component state>]
- Data State-
This parameter identifies the current state of the data server’s state machine.
[-data-operation <data operation>]
- Data Operation-
This parameter identifies the data server’s current operation.
[-data-halt-reason <halt reason>]
- Data Server Halt Reason-
This parameter identifies the event that caused the data server state machine to enter the HALTED state.
[-data-con-addr-type <address type>]
- Data Server Connect Type-
This parameter specifies the type of data connection established by the data server. The data connection can be established locally within a given system or between remote networked systems.
[-data-con-addr <text>]
- Data Server Connect Address-
This parameter specifies the connection endpoint information for the data server’s data connection.
[-data-con-port <integer>]
- Data Server Connect Port-
This parameter specifies the TCP/IP port that the data server will use when establishing a data connection.
[-data-bytes-processed <integer>]
- Data Bytes Processed-
This parameter represents the cumulative number of data stream bytes transferred between the backup or recovery method and the data connection during the current data operation.
[-mover-state <component state>]
- Mover State-
This parameter identifies the current state of the NDMP tape server’s mover state machine.
[-mover-mode <mover mode>]
- Mover Mode-
This parameter identifies the direction of the mover data transfer.
[-mover-pause-reason <pause reason>]
- Mover Pause Reason-
This parameter identifies the event that caused the mover state machine to enter the PAUSED state.
[-mover-halt-reason <halt reason>]
- Mover Halt Reason-
This parameter field identifies the event that caused the mover state machine to enter the HALTED state.
[-mover-record-size <integer>]
- Mover Record Size-
This parameter represents the current mover record size in bytes.
[-mover-record-num <integer>]
- Mover Record Number-
This parameter represents the last tape record processed by the mover.
[-mover-bytes-moved <integer>]
- Mover Bytes Moved-
This parameter represents the cumulative number of data stream bytes written to the data connection or the number of data stream bytes read from the data connection and written to the tape subsystem, depending on the mode of mover operation.
[-mover-seek-position <integer>]
- Mover Seek Position-
This parameter represents the data stream offset of the first byte the DMA requested the mover to transfer to the data connection during a mover read operation.
[-mover-bytes-left-to-read <integer>]
- Mover Bytes Left to Read-
This parameter represents the number of data bytes remaining to be transferred to the data connection to satisfy the current NDMP_MOVER_READ request.
[-mover-window-offset <integer>]
- Mover Window Offset-
This parameter represents the absolute offset of the first byte of the mover window within the overall data stream.
[-mover-window-length <integer>]
- Mover Window Length-
This parameter represents the length of the current mover window in bytes.
[-mover-position <integer>]
- Mover Position-
This parameter can be used to list only those sessions, whose mover position matches a specific value. Mover-position should be an integer.
[-mover-setrecordsize-flag {true|false}]
- Mover SetRecordSize Flag-
This parameter is used by the DMA to establish the record size used for mover-initiated tape read and write operations.
[-mover-setwindow-flag {true|false}]
- Mover SetWindow Flag-
This flag represents whether a mover window has been set or not. A mover window represents the portion of the overall backup stream that is accessible to the mover without intervening DMA tape manipulation.
[-mover-con-addr-type <address type>]
- Mover Connect Type-
This parameter specifies the type of data connection established by the mover. The data connection can be established locally within a given system or between remote networked systems.
[-mover-con-addr <text>]
- Mover Connect Address-
This parameter specifies the endpoint address or addresses that the mover will use when establishing a data connection.
[-mover-con-port <integer>]
- Mover Connect Port-
This parameter specifies the TCP/IP port that the mover will use when establishing a data connection.
[-eff-host <host type>]
- Effective Host-
This parameter indicates the host context in which the NDMP session runs. The valid values are: PRIMARY or PARTNER.
[-client-addr <text>]
- NDMP Client Address-
This parameter specifies the client’s IP address.
[-client-port <integer>]
- NDMP Client Port-
This parameter specifies the client’s port number.
[-spt-device-id <text>]
- SCSI Device ID-
This parameter specifies the SCSI device ID.
[-spt-ha <integer>]
- SCSI Host Adapter-
This parameter specifies the SCSI host adapter.
[-spt-scsi-id <integer>]
- SCSI Target ID-
This parameter specifies the SCSI target.
[-spt-scsi-lun <integer>]
- SCSI LUN ID-
This parameter specifies the SCSI LUN ID.
[-tape-device <text>]
- Tape Device-
This parameter specifies the name to identify the tape device.
[-tape-mode <mover mode>]
- Tape Mode-
This parameter specifies the mode in which tapes are opened.
[-node {<nodename>|local}]
- Node-
If this parameter is specified, the command displays information about the sessions running on the specified node only. Node should be a valid node name.
[-is-secure-control-connection {true|false}]
- Is Secure Control Connection-
This parameter specifies whether the control connection is secure or not.
[-data-backup-mode <text>]
- Data Backup Mode-
This parameter specifies whether the mode of data backup is Dump or SMTape.
[-data-path <text>]
- Data Path-
This parameter specifies the path of data being backed up.
[-source-addr <text>]
- NDMP Source Address-
This parameter specifies the control connection IP address of the NDMP session.
The following example displays diagnostic information about all the sessions in the cluster:
cluster1::> vserver services ndmp probe Vserver Name: vserver1 Session Identifier: 1000:7445 NDMP Version: 4 Session Authorized: true Data State: IDLE Data Operation: NOACTION Data Server Halt Reason: NA .... ... Vserver Name: vserver2 Session Identifier: 1000:7446 NDMP Version: 4 Session Authorized: true Data State: IDLE Data Operation: NOACTION Data Server Halt Reason: NA .... ...
The following example displays diagnostic information of sessions associated with Vserver vserver1 only:
cluster1::> vserver services ndmp probe -vserver vserver1 Vserver Name: vserver1 Session Identifier: 1000:7445 NDMP Version: 4 Session Authorized: true Data State: IDLE Data Operation: NOACTION Data Server Halt Reason: NA .... ... .... ...
