cluster show
Display cluster node members
The cluster show command displays information about the nodes in a cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the nodes that match this parameter value.
[-node-uuid <UUID>] - UUID
[-epsilon {true|false}] - Epsilon
Selects the nodes that match this parameter value. In a cluster, only one node can be designated as Epsilon at any given time. You can designate a node as Epsilon to add weight to its voting in a cluster with an even number of nodes.
[-eligibility {true|false}] - Eligibility
Selects the nodes that match this parameter value (true means eligible to participate in the cluster).
[-health {true|false}] - Health
Selects the nodes that match this parameter value (true means online).
The following example displays information about all nodes in the cluster:
cluster1::> cluster show
Node                  Health  Eligibility
node0                 true    true
node1                 true    true
node2                 true    true
node3                 true    true
The following example displays information about the node named node1:
cluster1::> cluster show -node node1
Node: node1
Eligibility: true
     Health: true
