ONTAP commands
security session limit location delete
Delete per-location session limit
This command allows deletion of a per-location management session limit.
-interface {cli|ontapi|rest} - Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-location <text> - Location (privilege: advanced)
The specified location to which this limit applies. The limit with the location name -default- (in the Default IPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
[-ipspace <IPspace>] - IPspace of Location (privilege: advanced)
This identifies the IPspace of the client location. If not specified, changes are made in the Default IPspace.
The following example illustrates deleting limits for management sessions from a specific set of locations.
cluster1::*> security session limit location delete -interface * -location 10.98.*
3 entries were deleted.
