statistics lun show
LUN throughput and latency metrics
This command continuously displays performance data for LUNs at a regular interval. The command output displays data in the following columns:
Lun - LUN name.
Vserver - vserver name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
Other Ops - other operations per second.
Read (Bps) - read throughput in bytes per second.
Write (Bps) - write throughput in bytes per second.
Latency(ms) - average latency for an operation in milliseconds.
[-lun <text>]
- Lun-
Selects the LUN for which you want to display performance data.
[-vserver <vserver name>]
- Vserver-
Selects the vserver for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies the maximum number of LUNs to display. The default setting is 25.
The following example displays LUN statistics:
cluster1::> statistics lun show cluster1 : 12/31/2013 16:00:04 *Total Read Write Other Read Write Latency Lun Vserver Ops Ops Ops Ops (Bps) (Bps) (ms) ---- ------- ------ ---- ----- ----- ------ ----- ------- lun1 vs1 58 13 15 29 310585 3014 39 lun0 vs2 56 0 11 45 8192 28826 47 [...]
