ONTAP commands
vserver cifs superuser delete
Deletes superuser permissions from a CIFS account
The vserver cifs superuser delete command removes the superuser privileges for the specified domain account in this Vserver. With superuser privileges, Data ONTAP bypasses some of the security checks.
-vserver <vserver name> - Vserver (privilege: advanced)
Vserver name.
-domain <CIFS domain> - Domain (privilege: advanced)
The domain name of accountname.
-accountname <CIFS account> - User (privilege: advanced)
The domain account name you want to remove superuser privileges.
The following example shows how to remove superuser privileges for ExampleUser in EXAMPLE domain for a Vserver vs1.
vs1::> vserver cifs superuser delete -domain EXAMPLE -accountname ExampleUser -vserver vs1
