lun igroup show
Display a list of initiator groups
This command displays status information for initiator groups (igroup). By default, the command displays status for all initiator groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Specifies the Vserver.
[-igroup <text>]- Igroup Name-
Selects the initiator groups that match this parameter value.
[-protocol <protocol_enum>]- Protocol-
Selects the initiator groups that match this parameter value (
FCP,iSCSI, ormixed). [-t, -ostype <Initiator Group OS Type>]- OS Type-
Selects the initiator groups that match this parameter value. The operating system types are
solaris -
windows -
hpux -
aix -
linux -
netware -
vmware -
openvms -
xen -
hyper_v
[-a, -portset <text>]- Portset Binding Igroup-
[-initiator <text>,…]- Initiators-
[-uuid <UUID>]- Igroup UUID-
[-delete-on-unmap {true|false}]- Delete on Last Unmap-
Selects the initiator groups that match this parameter value. A value of
truedisplays all the initiator groups that will be deleted automatically when they are no longer used in a LUN mapping relationship.
cluster1::> igroup show -instance
Vserver Name: vs0
Igroup Name: ig1
Protocol: mixed
OS Type: linux
Portset Binding Igroup: -
Igroup UUID: 358338ba-cfd6-11df-a9ab-123478563412
Initiators: iqn.1992-08.com.mv:abc (not logged in)
Vserver Name: vs0
Igroup Name: ig2
Protocol: mixed
OS Type: linux
Igroup UUID: 3fb136c7-cfd6-11df-a9ab-123478563412
Initiators: -
Vserver Name: vs1
Igroup Name: ig1
Protocol: mixed
OS Type: windows
Portset Binding Igroup: p1
Igroup UUID: 03accf6b-d08c-11df-a9ab-123478563412
Initiators: -
3 entries were displayed.
The example above displays information about all initiator groups.
