lun igroup show
PDF of this doc site
Creating your file...
Display a list of initiator groups
This command displays status information for initiator groups (igroup). By default, the command displays status for all initiator groups.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Specifies the Vserver.
[-igroup <text>]
- Igroup Name-
Selects the initiator groups that match this parameter value.
[-protocol <protocol_enum>]
- Protocol-
Selects the initiator groups that match this parameter value (
FCP
,iSCSI
, ormixed
). [-t, -ostype {solaris|windows|hpux|aix|linux|netware|vmware|openvms|xen|hyper_v}]
- OS Type-
Selects the initiator groups that match this parameter value. The operating system types are
solaris
windows
hpux
aix
linux
netware
vmware
openvms
xen
hyper_v
[-a, -portset <text>]
- Portset Binding Igroup-
[-initiator <text>,…]
- Initiators-
[-uuid <UUID>]
- Igroup UUID-
[-delete-on-unmap {true|false}]
- Delete on Last Unmap-
Selects the initiator groups that match this parameter value. A value of
true
displays all the initiator groups that will be deleted automatically when they are no longer used in a LUN mapping relationship.
cluster1::> igroup show -instance Vserver Name: vs0 Igroup Name: ig1 Protocol: mixed OS Type: linux Portset Binding Igroup: - Igroup UUID: 358338ba-cfd6-11df-a9ab-123478563412 Initiators: iqn.1992-08.com.mv:abc (not logged in) Vserver Name: vs0 Igroup Name: ig2 Protocol: mixed
