system node virtual-machine disk-object-store show
PDF of this doc site
Creating your file...
Display the list of object store configurations
The system node virtual-machine disk-object-store show
command displays the list of object store containers that contain each node's disks.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <nodename>]
- ONTAP Node Name (privilege: advanced)-
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-object-store-name <object store name>]
- ONTAP Name for this Object Store Config (privilege: advanced)-
Selects object store configurations with the specified name.
[-server <text>]
- Fully Qualified Domain Name of the Object Store Server (privilege: advanced)-
Selects containers on the specified server.
[-port <integer>]
- Port Number of the Object Store (privilege: advanced)-
Selects containers attached on the specified port.
[-container-name <text>]
- Container Name (privilege: advanced)-
Selects containers with the specified name.
[-azure-account <text>]
- Azure Storage Account (privilege: advanced)-
Selects containers in the specified Azure storage account.
[-alive {true|false}]
- Is Server Alive (privilege: advanced)-
Selects containers based on their aliveness state, as seen from the ONTAP node.
The following example displays the list of containers for each node in the cluster.
cluster1::*> system node virtual-machine disk-object-store show Object Store Node Name Azure Storage Account Container Name Alive ------------ ------------ ----------------------- ---------------- ----- node1 objstore1 storageaccount1 container1 true node2 objstore1 storageaccount1 container1 true 2 entries were displayed.
