ONTAP commands
lun portset add
Add iSCSI/FCP LIFs to a portset
This command adds existing iSCSI and FCP LIFs to a port set. To create a new port set, use the lun portset create command.
Use the network interface create command to create new LIFs.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-portset <text> - Portset Name
Specifies the port set you want to add the LIFs to.
-port-name <port_name>,…​ - LIF or TPG Name
Specifies the LIF name you want to add to the port set.
cluster1::> portset add -vserver vs1 -portset ps1 -port-name lif1
Adds port lif1 to port set ps1 on Vserver vs1.
