volume quota off
Turn off quotas for volumes
This command creates a job to deactivate quotas for the specified volume. You can monitor the progress of the job by using the job show and job watch-progress commands.
-vserver <vserver name>- Vserver Name-
This specifies the name of the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This specifies the name of the volume on which you are deactivating quotas.
[-foreground <true>]- Foreground Process-
This optionally specifies whether the job created for deactivating quotas runs as a foreground process. The default setting is
false(that is, the operation runs in the background). When set totrue, the command will not return until the job completes.
The following example deactivates quotas on the volume named vol1 , which exists on Vserver vs0 .
cluster1::> volume quota off -vserver vs0 -volume vol1 [Job 23] Job is queued: Quota OFF Operation on vserver vs0 volume vol1.
The following example uses a 7G-compatible command to deactivate quotas on the volume named vol1 which exists on Vserver vs0 .
cluster1::> vserver context vs0 vs0::> quota off vol1 [Job 25] Job is queued: Quota OFF Operation on vserver vs0 volume vol1.
