vserver iscsi security show
Show the current iSCSI authentication configuration
This command displays the default authentication and all initiator-specific authentication information. Data ONTAP authentication overrides all other service authentication methods.
{ [-fields <fieldname>,…​]
| [-address-masks ]
Display the list of IP Address ranges in CIDR notation that each initiator is allowed to originate from. If this list is empty, the initiator is allowed to log in from any IP address. The IPv4 or IPv6 address range contains a start address and an end address. The start and end addresses themselves are included in the range.
| [-address-ranges ]
Display the list of IP Address ranges that each initiator is allowed to originate from. If this list is empty, the initiator is allowed to log in from any IP address. The IPv4 or IPv6 address range contains a start address and an end address. The start and end addresses themselves are included in the range.
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to display authentication information that matches the Vserver name that you specify.
[-i, -initiator-name <text>] - Initiator Name
Use this parameter to display authentication information that matches the initiator that you specify.
[-s, -auth-type {CHAP|deny|none}] - Authentication Type
Use this parameter to display authentication information that matches the authentication type that you specify.
[-n, -user-name <text>] - Inbound CHAP User Name
Use this parameter to display authentication information that matches the inbound CHAP user name that you specify.
[-m, -outbound-user-name <text>] - Outbound CHAP User Name
Use this parameter to display authentication information that matches the outbound CHAP user name that you specify.
[-auth-chap-policy <local>] - Authentication CHAP Policy
Use this parameter to display authentication information that matches the authentication CHAP policy that you specify.
[-initiator-address-ranges {<ipaddr>|<ipaddr>-<ipaddr>}] - Initiator IP Address Ranges
Use this parameter to display authentication information that matches the initiator address range that you specify. If this list is empty, the initiator is allowed to log in from any IP address. The IPv4 or IPv6 address range contains a start address and an end address. The start and end addresses themselves are included in the range.
An example of a valid IPv4 address range is: '192.168.1.100-192.168.1.150'.
An example of a valid IPv6 address range is: '2001:db8::1000:1-2001:db8::1000:50'.
[-initiator-address-masks <IP Address/Mask>,…​] - Initiator IP Address Masks
Use this parameter to display authentication information that matches the initiator address masks that you specify. If this list is empty, the initiator is allowed to log in from any IP address. The IPv4 or IPv6 address range contains a start address and an end address. The start and end addresses themselves are included in the range.
An example of a valid IPv4 address range in CIDR notation is: 192.168.1.3/32.
An example of a valid IPv6 address range in CIDR notation is: 2001:db8::1000:1/128.
cluster1::> vserver iscsi security show -vserver vs1
                                  Auth   Auth CHAP Inbound CHAP  Outbound CHAP
Vserver    Initiator Name         Type   Policy    User Name     User Name
vs1       default                none   -         -             -
          iqn.2010-12.com.example:abcdefg
                                  CHAP   local     bob           bob2
2 entries were displayed.
Displays the authentication information for Vserver vs1.
cluster1::> vserver iscsi security show -address-ranges -vserver vs1
Vserver    Initiator Name         Initiator Address Ranges
vs1        iqn.2010-12.com.example:abcdefg
           iqn.2010-12.com.example:hijklmn
Displays the initiator and their valid address ranges for Vserver vs1.
cluster1::> vserver iscsi security show -address-masks -vserver vs1
          192.168.1.100/30
          192.168.1.104/29
          192.168.1.112/28
          192.168.1.128/28
          192.168.1.144/30
          192.168.1.148/31
          192.168.1.150/32
          2001:db8::1000:2/127
          2001:db8::1000:4/126
          2001:db8::1000:8/125
          2001:db8::1000:10/124
          2001:db8::1000:20/123
          2001:db8::1000:40/124
          2001:db8::1000:50/128
