ONTAP commands
security login role show-ontapi
Display the mapping between Data ONTAP APIs and CLI commands
The security login role show-ontapi command displays Data ONTAP APIs (ONTAPIs) and the CLI commands that they are mapped to.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-ontapi <text>] - ONTAPI Name
Use this parameter to view the corresponding CLI command for the specified API.
[-command <text>] - CLI Command
Use this parameter to view the corresponding API or APIs for the specified CLI command.
The following command displays all Data ONTAP APIs and their mapped CLI commands:
cluster1::> security login role show-ontapi
ONTAPI                      Command
aggr-add                    storage aggregate add-disks
aggr-check-spare-low        storage aggregate check_spare_low
aggr-create                 storage aggregate create
aggr-destroy                storage aggregate delete
aggr-get-filer-info         aggr
aggr-get-iter               storage aggregate show-view
aggr-offline                storage aggregate offline
aggr-online                 storage aggregate online
aggr-options-list-info      storage aggregate show
aggr-rename                 storage aggregate rename
aggr-restrict               storage aggregate restrict
aggr-set-option             storage aggregate modify
autosupport-budget-get      system node autosupport budget show
autosupport-budget-get-iter system node autosupport budget show
autosupport-budget-get-total-records
autosupport-budget-modify   system node autosupport budget modify
autosupport-config-get      system node autosupport show
autosupport-config-get-iter system node autosupport show
autosupport-config-get-total-records
autosupport-config-modify   system node autosupport modify
Press <space> to page down, <return> for next line, or 'q' to quit...
The following example displays all Data ONTAP APIs which are mapped to the specified CLI command:
cluster1::> security login role show-ontapi -command version
ONTAPI                      Command
system-get-ontapi-version   version
system-get-version          version
2 entries were displayed.
The following example displays the CLI command that is mapped to the specified Data ONTAPI API:
cluster1::> security login role show-ontapi -ontapi aggr-create
ONTAPI Name: aggr-create
    Command: storage aggregate create
