security login rest-role create
PDF of this doc site
Creating your file...
Add an access control REST role
The security login rest-role create
command creates an access-control role. An access-control role consists of a role name and a api to which the role has access. It optionally includes an access level (none, readonly, or all) for api. After you create an access-control role, you can apply it to a management-utility login account by using the security login modify or security login create commands.
-vserver <Vserver Name>
- Vserver-
This optionally specifies the Vserver name associated with the role.
-role <text>
- Role Name-
This specifies the role that is to be created.
-api <text>
- api path-
This specifies the api to which the role has access.
-access {none|readonly|all}
- Access Level-
This optionally specifies an access level for the role. Possible access level settings are none, readonly, and all. The default setting is
all
The following command creates an access-control role named "admin" for the vs1.example.com Vserver. The role has all access to the api "/api/storage/volume" but only within the "aggr0" aggregate.
cluster1::> security login rest-role create -role admin -api /api/storage/volume -access all -vserver vs1.example.com
