ONTAP commands
vserver vscan on-access-policy paths-to-exclude show
Display list of paths to exclude
The vserver vscan on-access-policy paths-to-exclude show command displays the list of paths that are excluded from scanning belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all on-access policies:
  • Vserver name
  • Policy name
  • List of Paths to exclude
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the policy names for the specified Vserver.
[-policy-name <Policy name>] - Policy
If you specify this parameter, the command displays information only about the specified policy name.
[-paths-to-exclude <File path>,…​] - File Paths Not to Scan
If you specify this parameter, the command displays information only about the policies that have the specified paths that are excluded from scanning.
The following example displays the list of paths that are excluded from scanning for all the policies:
cluster1::> vserver vscan on-access-policy paths-to-exclude  show
Vserver         Policy Name       Paths Excluded
cluster1        default_CIFS      \test\test1
vs1             default_CIFS      \test\test1
vs1             policy1           \test\test2,\test\test3
vs1             policy3           \test\test4
vs2             default_CIFS      \test\test1
vs2             policy2           \test\test5
6 entries were displayed.
Looking for answers?
Try Doc, our Gen AI Assistant.
