volume file clone deletion show
Show the supported file extensions for clone delete
The volume file clone deletion show
command displays the following information for clone delete:
Vserver Name
Volume Name
Minimum File Size Required for Clone Delete
List of Supported File Extensions for Clone Delete
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
Name of the vserver.
[-volume <volume name>]
- Volume Name-
Name of the volume.
[-extensions <text>,…]
- Supported Extensions for Clone Delete-
List of supported file extensions for Clone Delete.
[-minimum-size {<integer>[KB|MB|GB|TB|PB]}]
- Minimum Size Required for Clone delete-
Minimum file size required for Clone Delete.
The following example displays the clone deletion information for all volumes of all vservers.
cluster1::> volume file clone deletion show Vserver Volume Minimum Extensions Size ----------------- ------------------- ------- ---------------------- vs0 testvol 100B vmdk, vhd, vhdx, vswp vs0_root 0B - vs1 testvol 100G vmdk, vhd, vhdx, vswp vs1_root 0B -
The following example displays the clone deletion information for volume vol1
of vserver vs1
cluster1::> volume file clone deletion show -vserver vs0 -volume testvol Vserver Name: vs0 Volume Name: testvol Supported Extensions for Clone Delete: vmdk, vhd, vhdx, vswp Minimum Size Required for Clone delete: 100B
