vserver services ndmp generate-password
Generates NDMP password for a user
This command is used to generate NDMP password for a given user in the specified Vserver context. The generated NDMP password is based on the user's login password. For this reason regenerate it whenever the user's login password changes. This command fails if a user does not exist for the Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Specify the Vserver context for which password is to be generated.
[-user <text>] - User
Specify the user name for which the NDMP password needs to be generated.
[-password <text>] - Password
The generated NDMP password string that is used for authentication.
The following example shows the usage this command to generate NDMP password for a user belonging to a specific Vserver:
cluster1::> vserver services ndmp generate-password -vserver vserver1 -user user1
Vserver: vserver1
    User: user1
Password: a9cCCUp32yjGmBiD
