ONTAP 9.8 commands
storage path show-by-initiator
Display a list of paths to attached arrays from the initiator's perspective
The storage path show-by-initiator command displays path based statistics. The output is similar to the storage path show command but the output is listed by initiator.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Controller name
The name of the clustered node for which information is being displayed.
[-initiator <text>] - Initiator Port
Initiator port that the clustered node uses.
[-target-wwpn <text>] - Target Port
Target World Wide Port Name. Port on the storage array that is being used.
[-initiator-side-switch-port <text>] - Initiator Side Switch Port
Switch port connected to the clustered node.
[-target-side-switch-port <text>] - Target Side Switch Port
Switch port connected to the array.
[-array-name <array name>] - Array Name
Name of the storage array that is connected to the cluster.
[-tpgn <integer>] - Target Port Group Number
TPGN refers to the target port group to which the target port belongs. A target port group is a set of target ports which share the same LUN access characteristics and failover behaviors.
[-port-speed <text>] - Port Speed
Port Speed of the specified port.
[-path-io-kbps <integer>] - Kbytes of I/O per second on Path (Rolling Average)
Rolling average of I/O per second on the path.
[-path-iops <integer>] - Number of IOPS on Path (Rolling Average)
Rolling average of Kbytes of I/O per second on the path
[-initiator-io-kbps <integer>] - Kbytes of I/O per second on Initiator (Rolling Average)
Rolling average of I/O per second on the initiator port.
[-initiator-iops <integer>] - Number of IOPS on Initiator (Rolling Average)
Rolling average of Kbytes of I/O per second on the initiator port.
[-target-io-kbps <integer>] - Kbytes of I/O per second to Target (Rolling Average)
Rolling average of I/O per second on the target port.
[-target-iops <integer>] - Number of IOPS to Target (Rolling Average)
Rolling average of Kbytes of I/O per second on the target port.
vnv3070f20b::> storage path show-by-initiator
Node: vnv3070f20b
          Initiator I/O       Initiator Side     Path I/O          Target Side   Target I/O
Initiator        (KB/s)          Switch Port       (KB/s)          Switch Port       (KB/s)      Target Port Array Name
0a                    3 vnbr3850s4:4                    3        vnbr3850s5:15            3 200600a0b819e16f IBM_1722_1
                                                        0        vnbr3850s5:12            0 50060e80004291c0 HITACHI_DF600F_1
0c                   35 vnci9124s54:1-6                35     vnci9124s54:1-24           35 200700a0b819e16f IBM_1722_1
                                                        0     vnci9124s54:1-22            0 50060e80004291c2 HITACHI_DF600F_1
4 entries were displayed.
