vserver iscsi interface disable
Disable the specified interfaces for iSCSI service
This command disables the specified logical interfaces for an iSCSI service. Once disabled, all subsequent attempts to establish new iSCSI connections over the logical interface will fail.
-vserver <Vserver Name> - Vserver
Specifies the Vserver.
{ -lif <lif-name>,…​ - Logical Interface
Specifies the logical interfaces on a Vserver you want to disable.
| -a, -all <true> - All }
Specifies that all logical interfaces on the Vserver are disabled.
[-f, -force <true>] - Force
When set to true, forces the termination of any active iSCSI sessions without prompting you for a confirmation.
cluster1::> vserver iscsi interface disable -vserver vs_1 -lif vs_1.iscsi
Disables the iscsi logical interface vs_1.iscsi on Vserver vs_1.
