volume flexcache prepopulate start
Prepopulate flexcache volume
The `volume flexcache prepopulate start` command is used to prepopulate a FlexCache volume with the data of given directory path(s) from the origin volume.
The FlexCache prepopulate job fails when the directories listed with the -path-list have one or more non-existing paths.
-cache-vserver <vserver name>- Cache Vserver Name (privilege: advanced)-
This specifies the Vserver that has the FlexCache volume to be prepopulated.
-cache-volume <volume name>- Cache Volume Name (privilege: advanced)-
This specifies the FlexCache volume which needs to be prepopulated.
-path-list <text>,…- List of Paths (privilege: advanced)-
This specifies an array of directory names that need to be prepopulated in the FlexCache volume.
[-isRecursion {true|false}]- Recursively populate (privilege: advanced)-
This specifies that the directories listed with the
-path-listneed to be recursively prepopulated in the-cache-volumeFlexCache volume.The default value is true.
The following example triggers FlexCache volume prepopulate:
cluster1::> flexcache prepopulate start -cache-volume vol_cache2_vs3_c2_vol_origin1_vs1_c1 -cache-vserver vs3_c2 -path-list /dir1 -isRecursion false (volume flexcache prepopulate start) [JobId 164]: FlexCache prepopulate job queued.
cluster1::> flexcache prepopulate start -cache-volume vol_cache2_vs3_c2_vol_origin1_vs1_c1 -cache-vserver vs3_c2 -path-list /dir1 (volume flexcache prepopulate start) [JobId 188]: FlexCache prepopulate job queued.
cluster1::> flexcache prepopulate start -cache-volume vol_cache2_vs3_c2_vol_origin1_vs1_c1 -cache-vserver vs3_c2 -path-list /dir1, dir5, dir6
Error: command failed: Path(s) "dir5, dir6" does not exist in origin volume
"vol_origin1_vs1_c1" in Vserver "vs1_c1".
