system node root-mount delete
Delete a mount from one node to another node's root volume.
The system node root-mount delete
command removes a root-mount from one node in the cluster to another node's root volume. The root-mount is marked for immediate deletion by a background task. Use the system node root-mount show command to view the current status of root-mount or verify task completion.
-node <nodename>
- Owner of the Root-mount-
The node which has the mount.
-root-node <nodename>
- Root-mount Destination Node-
The node accessed by the mount.
This example shows the deletion of a root-mount from cluster1::nodeA
to cluster1::nodeB
and the verification of the command's successful completion.
cluster1::> system node root-mount show Node Root Node State Last Error ----------------- ----------------- ----------- ------------------------------- nodeA NodeB ready cluster1::> system node root-mount delete -node nodeA -root-node nodeB cluster1::> system node root-mount show This table is currently empty.
