      event filter delete
Delete existing event filters
The event filter delete command deletes an existing event filter, along with all its rules.
The system-defined event filters cannot be deleted.
For more information, see the event filter create command.
- -filter-name <text>- Filter Name
Use this mandatory parameter to specify the name of the event filter to delete.
The following example deletes an event filter named filter1:
cluster1::> event filter show
Filter Name Rule     Rule      Message Name           SNMP Trap Type  Severity
            Position Type
default-trap-events
            1        include   *                      *               EMERGENCY, ALERT
            2        include   *                      Standard, Built-in
            3        exclude   *                      *               *
filter1
            1        include   wafl.*                 *               EMERGENCY
            2        exclude   *                      *               *
important-events
            2        include   callhome.*             *               ERROR
            3        exclude   *                      *               *
no-info-debug-events
            1        include   *                      *               EMERGENCY, ALERT, ERROR, NOTICE
            2        exclude   *                      *               *
10 entries were displayed.
cluster1::> event filter delete -filter-name filter1
            Position Type
default-trap-events
            3        exclude   *                      *               *
important-events
            3        exclude   *                      *               *
            2        exclude   *                      *               *
8 entries were displayed.
 PDFs
PDFs
