ONTAP 9.8 commands
vserver iscsi connection shutdown
Shut down a connection on a node
This command shuts down a specified iSCSI connection within a session. If you want to shut down all iSCSI connections in a session, use the vserver iscsi session shutdown command.
-vserver <Vserver Name> - Vserver (privilege: advanced)
Specifies the Vserver.
-tpgroup <text> - Target Portal Group (privilege: advanced)
Specifies the target portal group that contains the connection you want to shut down.
-tsih <integer> - Target Session ID (privilege: advanced)
Specifies the target session ID that you want to shut down.
-connection-id <integer> - Connection ID (privilege: advanced)
Specifies the connection ID that you want to shut down.
cluster1::*> vserver iscsi connection shutdown -vserver vs_1 -tpgroup tpgroup_1 -tsih 4 -connection-id 0
Forces the shutdown of an iSCSI connection with the connection ID of 0 on Vserver vs_1 in tpgroup tpgroup_1, target session ID 4.
