system configuration backup show
Show configuration backup information
The system configuration backup show command displays information about saved configuration backups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects configuration backups that are saved on the node you specify.
[-backup <text>] - Backup Name
Selects configuration backups that have the backup name you specify.
[-backup-type {node|cluster}] - Backup Type
Selects configuration backups of the type you specify.
[-time <MM/DD HH:MM:SS>] - Backup Creation Time
Selects configuration backups that were saved on the date and time you specify.
[-cluster-name <text>] - Cluster Name
Selects configuration backups that were saved in the cluster that has the name you specify.
[-cluster-uuid <UUID>] - Cluster UUID
Selects configuration backups that were saved in the cluster that has the UUID you specify.
[-size {<integer>[KB|MB|GB|TB|PB]}] - Size of Backup
Selects configuration backups that have the file size you specify.
[-nodes-in-backup {<nodename>|local}] - Nodes In Backup
Selects configuration backups that include the configuration of the nodes you specify.
[-version <text>] - Software Version
Selects configuration backups that have the software version you specify.
[-is-auto {true|false}] - Backup Created from Schedule (true or false)
A value of true selects configuration backups that were created from a schedule. A value of false selects configuration backups that were created manually.
[-schedule <text>] - Name of Backup Schedule
Selects configuration backups that were created by the schedule you specify.
The following example shows typical output for this command.
cluster1::*> system configuration backup show
Node       Backup Tarball                            Time               Size
node1      cluster1.8hour.2011-02-22.18_15_00.7z     02/22 18:15:00     7.78MB
node1      cluster1.8hour.2011-02-23.02_15_00.7z     02/23 02:15:00     7.98MB
node1      cluster1.8hour.2011-02-23.10_15_00.7z     02/23 10:15:00     7.72MB
node1      cluster1.daily.2011-02-22.00_10_00.7z     02/22 00:10:00     7.19MB
node1      cluster1.daily.2011-02-23.00_10_00.7z     02/23 00:10:00     7.99MB
Press <space> to page down, <return> for next line, or 'q' to quit... q
5 entries were displayed.
