      system ha interconnect ood clear-error-statistics
Clear error statistics
The system ha interconnect ood clear-error-statistics command enables you to clear all the error statistics collected for the out-of-order delivery-capable high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
- -node <nodename>- Node (privilege: advanced)
This mandatory parameter specifies which node will have the error statistics cleared. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood clear-error-statistics -node ic-f2554-03
 PDFs
PDFs
