snapmirror mediator show
Show mediator information
The snapmirror mediator show command retrieves the list of mediator configurations.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-mediator-address <IP Address>]- Mediator IP Address-
Ip address of the mediator.
[-peer-cluster <text>]- Peer Cluster Name-
Peer cluster name.
[-connection-status {connected|unreachable|suspended|unusable|misconfigured|removing|not-configured|unknown|adding}]- Connection Status-
Connection status of the cluster with the mediator.
[-quorum-status {unknown|true|false}]- Mediator Quorum Status-
Shows whether the SnapMirror Consistency Group relationships are synchronized with mediator.
[-health-fetch-timeout <integer>]- Peer Health Fetch Timeout-
Timeout value (in seconds) for peer-cluster health fetch via mediator.
[-connection-timeout <integer>]- Connection Timeout-
Timeout value (in seconds) for mediator connection.
The following example shows the list of mediator configurations.
clusA::*> snapmirror mediator show
Mediator Address Peer Cluster Connection Status Quorum Status
10.140.102.227 clusB unreachable true
clusA::*> snapmirror mediator show -instance
Mediator Uuid: 416fbdee-c982-11e9-9034-005056a7124c
Mediator IP Address: 10.140.102.227
Peer Cluster: clusB
Peer Cluster Uuid: 771d9b13-c973-11e9-928e-005056a7a882
Connection Status: unreachable
Quorum Status: true
Health Fetch Timeout: 5
Connection Timeout: 5
