network options cluster-health-notifications show
Display cluster health notification options
The network options cluster-health-notifications show command displays whether the node's cluster health notifications are enabled.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
This parameter specifies the node for which the cluster health notification status will be displayed.
- [-enabled {true|false}]- Cluster Health Notifications Enabled
Selects the entries that match this parameter value.
The following example displays the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications show -node node1
                                 Node: node1
 Cluster Health Notifications Enabled: true
 PDFs
PDFs
