ONTAP 9.8 commands
system service-processor show
Display the Service Processor information
The system service-processor show command displays information about the Service Processor of each node in a cluster. You can limit output to specific types of information and specific nodes in the cluster, or filter output by specific field values.
In case a node is offline or its Service Processor management daemon is down, the command displays the last known IP address of its Service Processor. Only the IP address is displayed in such cases.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects information for the Service Processor of the specified node.
[-type {SP|NONE|BMC}] - Type of Device
Selects information for the Service Processors of the specified type.
[-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}] - Status
Selects information for the Service Processors whose status matches the specified value.
[-ip-configured {true|false}] - Is Network Configured
Selects information for the Service Processors whose network is configured (true ) or not configured (false ).
[-address <IP Address>,…​] - Public IP Address
Selects information for the Service Processors that use the specified IP address or addresses.
[-mac <MAC Address>] - MAC Address
Selects information for the Service Processors that use the specified MAC address.
[-fw-version <text>] - Firmware Version
Selects information for the Service Processors that are running the specified firmware version.
[-part-num <text>] - Part Number
Selects information for the Service Processors that have the specified part number.
[-serial-num <text>] - Serial Number
Selects information for the Service Processors that have the specified serial number.
[-dev-rev <text>] - Device Revision
Selects information for the Service Processors that have the specified device revision.
[-autoupdate-enabled {true|false}] - Is Firmware Autoupdate Enabled
Selects information for the Service Processors that have the specified status for firmware automatic update.
The following example displays basic information for the Service Processors of all the nodes.
cluster1::> system service-processor show
                               IP           Firmware
Node          Type Status      Configured   Version   IP Address
node1         SP   online      true         2.2X5     192.168.1.201
node2         SP   online      true         2.2X5     192.168.1.202
2 entries were displayed.
cluster1::>
The following example displays all available information for the Service Processors of all the nodes.
cluster1::> system service-processor show -instance
Node: node1
                     Type of Device: SP
                             Status: online
              Is Network Configured: true
                  Public IP Address: 192.168.1.201
                        MAC Address: ab:cd:ef:fe:ed:01
                   Firmware Version: 2.2X5
                        Part Number: Not Applicable
                      Serial Number: Not Applicable
                    Device Revision: Not Applicable
     Is Firmware Autoupdate Enabled: true
Node: node2
                     Type of Device: SP
                             Status: online
                  Public IP Address: 192.168.1.202
                        MAC Address: ab:cd:ef:fe:ed:02
cluster1::>
The following example displays only the type, status and firmware version for the Service Processors of all the nodes.
cluster1::> system service-processor show -fields type,status,fw-version
node          type status fw-version
node1         SP   online 2.2X5
node2         SP   online 2.2X5
cluster1::>
