system switch fibre-channel show
Display back-end fibre-channel switch information
The system switch fibre-channel show command displays information about all the back-end fibre-channel (FC) switches in the MetroCluster configuration. The back-end switches must have been previously added for monitoring using the system switch fibre-channel add command. If no parameters are specified, the default command displays the following information about the back-end FC switches:
Switch
Symbolic Name
Vendor
Model
Switch WWN
Is Monitored
Monitor Status
To display detailed profile information about a single back-end FC switch, use the -switch-name parameter.
[-fields <fieldname>,…] -
Displays the specified fields for all the back-end FC switches, in column-style output.
[-connectivity ] -
Displays the following details about the connectivity from the back-end FC switch to connected entities:
Port name
Port operating mode
Port world wide name
Peer port world wide name
Peer type
Additional information about peer
Displays the following details about the connectivity from the node to the back-end FC switch:
Node name
Adapter name
Switch port name
Switch port speed
Adapter type
[-cooling ] -
Displays the following details about the fans and temperature sensors on the back-end FC switch:
Fan name
Fan speed in rotations per minute (RPM)
Fan operational status
Temperature sensor name
Temperature sensor reading in Celsius ©
Temperature sensor status
[-error ] -
Displays the errors related to the back-end FC switch.
[-port ] -
Displays the following details about the back-end FC switch ports:
Port name
Port administrative status
Port operational status
Port operating mode
Whether SFP is present in the port
Port speed in gigabits per second (Gbps)
Port BB credit
[-power ] -
Displays the following details about the back-end FC switch power supplies:
Power supply name
Power supply serial number
Power supply operational status
[-san-config ] -
Displays the following details about the Virtual Storage Area Networks (VSAN) and Zones of the back-end FC switch:
VSAN identifier
VSAN name
VSAN operational status
Type of load balancing configured for the VSAN
Where in-order-delivery set for the VSAN
Whether the auto power reset of the PSU is enabled
VAN member switch name and port
Zone name
VSAN ID of the zone
Zone member switch name and port
Zone member port id
Zone member port world wide name
[-sfp ] -
Displays the following details about the back-end FC switch ports small form-factor pluggable (SFP):
Port name
Type of SFP
SFP transmitter type
SFP vendor
SFP part number
SFP serial number
[-stats ] -
Port name
Frames received through the port (Rx Frames)
Frames transmitted through the port (Tx Frames)
Octets received through the port (Rx Octets)
Octets transmitted through the port (Tx Octets)
Port error frames
[-instance ]} -
Displays expanded information about all the back-end FC switches in the system. If a back-end FC switch is specified, then this parameter displays the same detailed information for the back-end FC switch you specify as does the -switch-name parameter.
[-switch-name <text>]- FC Switch Name-
Displays information only about the back-end FC switches that match the name you specify.
[-switch-wwn <text>]- Switch World Wide Name-
Displays information only about the back-end FC switches that match the switch wwn you specify.
[-switch-symbolic-name <text>]- Switch Symbolic Name-
Displays information only about the back-end FC switches that match the switch symbolic name you specify.
[-switch-fabric-name <text>]- Fabric Name-
Displays information only about the back-end FC switches that match the switch fabric you specify.
[-domain-id <integer>]- Switch Domain ID-
Displays information only about the back-end FC switches that match the switch domain id you specify.
[-switch-role {unknown|primary|subordinate}]- Switch Role in Fabric-
Displays information only about the back-end FC switches that match the switch role you specify.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version-
Displays information only about the back-end FC switches that match the switch SNMP version you specify.
[-switch-model <text>]- Switch Model-
Displays information only about the back-end FC switches that match the switch model you specify.
[-switch-vendor {unknown|Brocade|Cisco}]- Switch Vendor-
Displays information only about the back-end FC switches that match the switch vendor you specify.
[-fw-version <text>]- Switch Firmware Version-
Displays information only about the back-end FC switches that match the switch firmware version you specify.
[-serial-number <text>]- Switch Serial Number-
Displays information only about the back-end FC switches that match the switch serial number you specify.
[-switch-ipaddress <IP Address>]- Switch IP Address-
Displays information only about the back-end FC switches that match the switch IP address you specify.
[-switch-status {unknown|ok|error}]- Switch Status-
Displays information only about the back-end FC switches that match the switch status you specify.
[-snmp-community <text>]- (DEPRECATED)-SNMPv2c Community or SNMPv3 Username-
This parameter is deprecated and may be removed in a future release of Data ONTAP. Use -snmp-community-or-usernameinstead.Displays information only about the back-end FC switches that match the switch SNMPv2c community or SNMPv3 username you specify.
[-snmp-community-or-username <text>]- SNMPv2c Community or SNMPv3 Username-
[-profile-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Profile Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the profile data last successful refresh timestamp you specify.
[-is-monitoring-enabled {true|false}]- Is Monitoring Enabled for Switch-
Displays information only about the back-end FC switches that match the switch monitoring value you specify.
[-blades <integer>,…]- Director-Class Switch Blades to Monitor-
Displays information only about the back-end FC switches that match the blade value you specify.
[-engine-id <Hex String>]- Engine ID of SNMPv3 Capable Switch-
Displays information only about the back-end FC switches that match the SNMPv3 engine-id you specify.
[-psu-name-list <text>,…]- Switch Power Supply Name List-
Displays information only about the back-end FC switches that have the power supply units with the names you specify.
[-psu-serial-number-list <text>,…]- Switch Power Supply Serial Number List-
Displays information only about the back-end FC switches that have the power supply units with the serial numbers you specify.
[-psu-status-list {unknown|normal|warning|faulty|not-present}]- Switch Power Supply Status List-
Displays information only about the back-end FC switches that have the power supply units with the statuses you specify.
[-psu-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Power Supply Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the power supply unit data last successful refresh timestamp you specify.
[-temp-sensor-name-list <text>,…]- Switch Temperature Sensor Name List-
Displays information only about the back-end FC switches that have the temperature sensors with the names you specify.
[-temp-sensor-reading-list <integer>,…]- Switch Temperature Sensor Reading © List-
Displays information only about the back-end FC switches that have the temperature sensors with the readings you specify.
[-temp-sensor-status-list {unknown|normal|warning|critical}]- Switch Temperature Sensor Status List-
Displays information only about the back-end FC switches that have the temperature sensors with the statuses you specify.
[-temp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Temperature Sensor Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the temperature sensor data last successful refresh timestamp you specify.
[-fan-name-list <text>,…]- Switch Fan Name List-
Displays information only about the back-end FC switches that match the fans with the names you specify.
[-fan-rpm-list <integer>,…]- Switch Fan Speed (RPM) List-
Displays information only about the back-end FC switches that match the fans with the RPM speeds you specify.
[-fan-status-list {unknown|operational|failed|not-operational|not-present}]- Switch Fan Operational Status List-
Displays information only about the back-end FC switches that match the fans with the statuses you specify.
[-fan-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Fan Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the fan data last successful refresh timestamp you specify.
[-vsan-index-list <integer>,…]- Switch VSAN Index List-
Displays information only about the back-end FC switches that have the VSANs with the indexes you specify.
[-vsan-name-list <text>,…]- Switch VSAN Name List-
Displays information only about the back-end FC switches that have the VSANs with the names you specify.
[-vsan-oper-status-list {up|down}]- Switch VSAN Operational Status List-
Displays information only about the back-end FC switches that have the VSANs with the operational statuses you specify.
[-vsan-load-balancing-type-list {src-id-dest-id|src-id-dest-id-ox-id}]- Switch VSAN Load balancing Type List-
Displays information only about the back-end FC switches that have the VSANs with the load balancing types you specify.
[-is-vsan-iod-list {true|false}]- Is In-order Delivery Set for VSAN List-
Displays information only about the back-end FC switches that have the VSANs with the IOD setting you specify.
[-vsan-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch VSAN Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the VSAN data last successful refresh timestamp you specify.
[-member-switch-name-list <text>,…]- Member Switch List-
Displays information only about the back-end FC switches that have the VSANs with the member switch names you specify.
[-member-switch-port-name-list <text>,…]- Member Switch Port Name List-
Displays information only about the back-end FC switches that have the VSANs with the memeber switch port names you specify.
[-vsan-id-list <integer>,…]- Zone VSAN ID List-
Displays information only about the back-end FC switches that have the VSANs with the IDs you specify.
[-zone-name-list <text>,…]- Switch Zone Name List-
Displays information only about the back-end FC switches that have the zones with the names you specify.
[-zone-member-sw-domain-id-list <integer>,…]- Zone Member Switch Port Domain ID List-
Displays information only about the back-end FC switches that have the zones with the member switch domain ids you specify.
[-zone-member-port-name-list <text>,…]- Zone Member Port List-
Displays information only about the back-end FC switches that have the zones with the port names you specify.
[-zone-member-port-wwn-list <text>,…]- Zone Member WWPN List-
Displays information only about the back-end FC switches that have the zones with the port WWNs you specify.
[-zone-member-port-switch-name-list <text>,…]- Zone Member Switch WWN List-
Displays information only about the back-end FC switches that have the zones with the member port hosting switch names you specify.
[-zone-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Zone Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the zone data last successful refresh timestamp you specify.
[-zone-member-wwn-list <text>,…]- Zone Member WWN List-
Displays information only about the back-end FC switches that have the zones with the member WWNs you specify.
[-zone-member-port-id-list <text>,…]- Zone Member Port ID List-
Displays information only about the back-end FC switches that have the zones with the member port ids you specify.
[-port-wwn-list <text>,…]- Switch Port World Wide Name (WWPN) List-
Displays information only about the back-end FC switches that have the ports with the WWNs you specify.
[-port-name-list <text>,…]- Switch Port Name List-
Displays information only about the back-end FC switches that have the ports with the names you specify.
[-port-admin-status-list {unknown|enabled|disabled}]- Switch Port Admin Status List-
Displays information only about the back-end FC switches that have the ports with administrative statuses you specify.
[-port-oper-status-list {unknown|online|offline}]- Switch Port Operational Status List-
Displays information only about the back-end FC switches that have the ports with operational statuses you specify.
[-port-mode-list {unknown|auto|F-port|FL-port|E-port|TE-port|U-port|G-port|other|EX-port|D-port|SIM-port|VE-port|AE-port|AF-port}]- Switch Port Mode List-
Displays information only about the back-end FC switches that have the ports with the operating modes you specify.
[-port-oper-speed-list <integer>,…]- Switch Port Current Speed (in Gbits/sec) List-
Displays information only about the back-end FC switches that have the ports with the operational speeds you specify.
[-port-bb-credit-list <integer>,…]- Switch Port BB Credit List-
Displays information only about the back-end FC switches that have the ports with the BB credits you specify.
[-port-sfp-present-list {true|false}]- Switch Port Is SFP Present List-
Displays information only about the back-end FC switches that have the ports with the SFP present values you specify.
[-port-peer-wwpn-list <text>,…]- Switch Port Peer WWPN List-
Displays information only about the back-end FC switches that have the ports with the peer port WWPNs you specify.
[-port-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Port Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the port data last successful refresh timestamp you specify.
[-port-stat-name-list <text>,…]- Switch Port Name List-
[-port-tx-frames-list <integer>,…]- Switch Port Transmitted Frame Count List-
Displays information only about the back-end FC switches that have the ports with the transmitted frames values you specify.
[-port-rx-frames-list <integer>,…]- Switch Port Received Frame Count List-
Displays information only about the back-end FC switches that have the ports with the received frames values you specify.
[-port-tx-octets-list <integer>,…]- Switch Port Total Transmitted Octets List-
Displays information only about the back-end FC switches that have the ports with the transmitted octets values you specify.
[-port-rx-octets-list <integer>,…]- Switch Port Total Received Octets List-
Displays information only about the back-end FC switches that have the ports with the received octets values you specify.
[-port-frame-error-list <integer>,…]- Switch Port Frame Error Count List-
Displays information only about the back-end FC switches that have the ports with the error frame values you specify.
[-port-stat-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Port Stat Data Last Update Timestamp-
Displays information only about the back-end FC switches that match the port statistics data last successful refresh timestamp you specify.
[-sfp-port-name-list <text>,…]- Switch Port Name List-
[-sfp-type-list {unknown|other|gbic|embedded|glm|gbic-with-serial-id|gbic-without-serial-id|sfp-with-serial-id|sfp-without-serial-id|xfp|x2-short|x2-medium|x2-tall|xpak-short|xpak-medium|xpak-tall|xenpak|sfp-dw-dm|qsfp|x2-dw-dm|gbic-not-installed|small-form-factor}]- Switch Port SFP Type List-
Displays information only about the back-end FC switches that have the ports with the SFP types you specify.
[-sfp-tx-type-list {unknown|long-wave-laser|short-wave-laser|long-wave-laser-cost-reduced|electrical|ten-gig-base-sr|ten-gig-base-lr|ten-gig-base-er|ten-gig-base-lx4|ten-gig-base-sw|ten-gig-base-lw|ten-gig-base-ew}]- Switch Port SFP Transmitter Type List-
Displays information only about the back-end FC switches that have the ports with the SFP transmitter types you specify.
[-sfp-vendor-list <text>,…]- Switch Port SFP Vendor List-
Displays information only about the back-end FC switches that have the ports with the SFP vendors you specify.
[-sfp-part-number-list <text>,…]- Switch Port SFP Part Number List-
Displays information only about the back-end FC switches that have the ports with the SFP part numbers you specify.
[-sfp-serial-number-list <text>,…]- Switch Port SFP Serial Number List-
Displays information only about the back-end FC switches that have the ports with the SFP serial numbers you specify.
[-sfp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Port SFP Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the port SFP data last successful refresh timestamp you specify.
[-switch-error-text-list <text>,…]- Switch Error Text List-
Displays information only about the back-end FC switches that have the errors you specify.
[-conn-switch-port-name-list <text>,…]- Switch Port Name List-
[-conn-switch-port-mode-list {unknown|auto|F-port|FL-port|E-port|TE-port|U-port|G-port|other|EX-port|D-port|SIM-port|VE-port|AE-port|AF-port}]- Switch Port Operating Mode List-
[-conn-switch-port-wwn-list <text>,…]- Switch Port WWN List-
[-conn-switch-port-peer-port-wwn-list <text>,…]- Switch Port Peer Port WWN List-
Displays information only about the back-end FC switches that have the ports with the peer port WWNs you specify.
[-conn-switch-port-peer-info-list <text>,…]- Switch Port Peer Host & Port Name List-
Displays information only about the back-end FC switches that have the ports with the peer information values you specify.
[-conn-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Connectivity Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the switch connectivity data last successful refresh timestamp you specify.
[-conn-switch-port-peer-type-list {unknown|bridge|switch|fcp-adapter|fcvi-adapter}]- Switch Port Peer Type List-
Displays information only about the back-end FC switches that have the ports connected to the peer types you specify.
[-switch-port-name-list <text>,…]- Switch Port Name List-
[-switch-port-speed-list <integer>,…]- Switch Port Speed (in Gbps) List-
Displays information only about the back-end FC switches that have the ports with the speeds you specify.
[-node-name-list <nodename>,…]- Node Name List-
Displays information only about the back-end FC switches that are connected to the nodes you specify.
[-adapter-name-list <text>,…]- Node Adapter Name List-
Displays information only about the back-end FC switches that are connected to the adapters you specify.
[-adapter-port-name-list <text>,…]- Node Adapter Port Name List-
Displays information only about the back-end FC switches that are connected to the adapter ports you specify.
[-adapter-type-list {unknown|FCP-Initiator|FC-VI|FCP-Target}]- Node Adapter Type List-
Displays information only about the back-end FC switches that are connected to the types of adapters you specify.
[-path-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Path Data Last Successful Refresh Timestamp-
Displays information only about the back-end FC switches that match the node to switch path data last successful refresh timestamp you specify.
[-name-list <text>,…]- Switch Name List-
Displays information only about the back-end FC switches that match the names you specify.
[-domain-id-list <integer>,…]- Switch Domain ID List-
Displays information only about the back-end FC switches that match the domain ids you specify.
[-wwn-list <text>,…]- Switch WWN List-
Displays information only about the back-end FC switches that match the switch WWNs you specify.
[-role-list {unknown|primary|subordinate}]- Switch Role in Fabric List-
Displays information only about the back-end FC switches that match the switch roles you specify.
[-address-list <IP Address>,…]- Switch IP Address List-
Displays information only about the back-end FC switches that match the switch IP addresses you specify.
The following example displays information about all back-end FC switches:
cluster::> system switch fibre-channel show
Symbolic Is Monitor
Switch Name Vendor Model Switch WWN Monitored Status
Cisco_10.226.197.34
mcc-cisco-8Gb-fab-4
Cisco DS-C9148-16P-K9
2000547fee78f088 true ok
Cisco_10.226.197.35
mcc-cisco-8Gb-fab-3
2000547fee78f0f0 true ok
Cisco_10.226.197.36
mcc-cisco-8Gb-fab-2
2000547fee78efb0 true ok
Cisco_10.226.197.37
mcc-cisco-8Gb-fab-1
2000547fee78f0d8 true ok
4 entries were displayed.
cluster::>
The following example displays connectivity (switch to peer and node to switch) information about all back-end FC switches:
cluster::> system switch fibre-channel show -connectivity
Switch Name: Cisco_10.226.197.36
Switch WWN: 2000547fee78efb0
Fabric WWN: 2001547fee78efb1
Vendor: Cisco
Model: DS-C9148-16P-K9
Errors: -
Last Update Time: 7/31/2014 14:16:42 -04:00
Connectivity:
Port Name Port Mode Port WWN Peer Port WWN Peer Type Peer Info
fc1/1 F-port 2001547fee78efb0 2100001086607d34 unknown unknown
fc1/3 F-port 2003547fee78efb0 21000024ff3dd9cb unknown unknown
fc1/4 F-port 2004547fee78efb0 21000024ff3dda8d unknown unknown
fc1/5 F-port 2005547fee78efb0 500a0980009af880 unknown unknown
fc1/6 F-port 2006547fee78efb0 500a0981009af370 unknown unknown
fc1/11 TE-port 200b547fee78efb0 200b547fee78f088 switch Cisco_10.226.197.34:fc1/11
fc1/12 TE-port 200c547fee78efb0 200c547fee78f088 switch Cisco_10.226.197.34:fc1/12
fc1/13 F-port 200d547fee78efb0 2100001086609e22 unknown unknown
fc1/15 F-port 200f547fee78efb0 21000024ff3dd91b unknown unknown
fc1/16 F-port 2010547fee78efb0 21000024ff3dbef5 unknown unknown
fc1/17 F-port 2011547fee78efb0 500a0981009afda0 unknown unknown
fc1/18 F-port 2012547fee78efb0 500a0981009a9160 unknown unknown
fc1/25 F-port 2019547fee78efb0 21000010866037e8 bridge ATTO_10.226.197.17:1
fc1/27 F-port 201b547fee78efb0 21000024ff3dd9d3 fcvi-adapter dpg-mcc-3240-15-a1:fcvi_device_1
fc1/28 F-port 201c547fee78efb0 21000024ff3dbe3d fcvi-adapter dpg-mcc-3240-15-a2:fcvi_device_1
fc1/29 F-port 201d547fee78efb0 500a0980009ae0a0 fcp-adapter dpg-mcc-3240-15-a2:0c
fc1/30 F-port 201e547fee78efb0 500a0981009aef40 fcp-adapter dpg-mcc-3240-15-a1:0d
Last Update Time: 7/31/2014 14:26:48 -04:00
Path:
Switch
Port
Node Adapter Switch Port Speed Adapter Type
dpg-mcc-3240-15-a1 0d fc1/30 4Gbps FCP-Initiator
dpg-mcc-3240-15-a1 fcvi_device_1 fc1/27 8Gbps FC-VI
dpg-mcc-3240-15-a2 0c fc1/29 4Gbps FCP-Initiator
dpg-mcc-3240-15-a2 fcvi_device_1 fc1/28 8Gbps FC-VI
The following command displays cooling (temperature sensors and fans) information about all back-end FC switches:
cluster::> system switch fibre-channel show -cooling
Switch Name: Cisco_10.226.197.34
Switch WWN: 2000547fee78f088
Vendor: Cisco
Errors: -
Last Update Time: 7/31/2014 14:26:58 -04:00
Fans:
Fan RPM Status
Fan Module-1 - operational
Fan Module-2 operational
Fan Module-3 operational
Fan Module-4 operational
Last Update Time: 7/31/2014 14:27:10 -04:00
Temperature Sensors:
Sensor Temp (C) Status
module-1 Outlet 27 normal
module-1 Outlet 29 normal
module-1 Intake 26 normal
module-1 Intake 28 normal
The following command displays the error information about all back-end FC switches:
cluster::> system switch fibre-channel show -error
Cisco_10.226.197.34(2000547fee78f088): Switch is Unreachable over Management Network.
Switch Name: Cisco_10.226.197.35
Switch WWN: 2000547fee78f0f0
Cisco_10.226.197.35(2000547fee78f0f0): Switch is Unreachable over Management Network.
Cisco_10.226.197.36(2000547fee78efb0): Switch is Unreachable over Management Network.
Switch Name: Cisco_10.226.197.37
Switch WWN: 2000547fee78f0d8
Cisco_10.226.197.37(2000547fee78f0d8): Switch is Unreachable over Management Network.
The following command displays the detailed information about all the back-end FC switches:
cluster::> system switch fibre-channel show -instance
Switch Domain: -
Switch Role: -
Vendor: Cisco
Firmware Version: 6.2(1)
Management IP: 10.226.197.34
Errors: Cisco_10.226.197.34(2000547fee78f088): Switch is Unreachable over Management Network.
Last Update Time: 7/31/2014 14:41:28 -04:00
Fabric:
Switch Name Domain WWN Role IP Address
Cisco_10.226.197.34 0 2000547fee78f088 unknown 10.226.197.34
Cisco_10.226.197.36 0 2000547fee78efb0 unknown 10.226.197.36
The following command displays port information about all back-end FC switches:
cluster::> system switch fibre-channel show -port
Vendor: Cisco
Errors: -
Ports:
Admin Oper SFP Speed BB
Port Name Port WWN Status Status Port Mode Present (Gbps) Credit PeerPortWWN
fc1/1 2001547fee78f088
enabled online F-port true 8 1 2100001086608b76
fc1/2 2002547fee78f088
enabled offline auto true 0 1
fc1/3 2003547fee78f088
enabled online F-port true 8 1 21000024ff48edd9
fc1/4 2004547fee78f088
enabled online F-port true 8 1 21000024ff3dd981
fc1/5 2005547fee78f088
enabled online F-port true 4 1 500a098001057f98
fc1/6 2006547fee78f088
enabled online F-port true 4 1 500a098101069778
fc1/7 2007547fee78f088
fc1/8 2008547fee78f088
fc1/9 2009547fee78f088
fc1/10 200a547fee78f088
enabled offline auto true 0 32
fc1/11 200b547fee78f088
enabled offline TE-port true 8 32 200b547fee78efb0
fc1/12 200c547fee78f088
enabled offline TE-port true 8 32 200c547fee78efb0
fc1/13 200d547fee78f088
enabled online F-port true 8 32 2100001086609c2e
fc1/14 200e547fee78f088
fc1/15 200f547fee78f088
fc1/16 2010547fee78f088
fc1/17 2011547fee78f088
fc1/18 2012547fee78f088
fc1/19 2013547fee78f088
fc1/20 2014547fee78f088
fc1/21 2015547fee78f088
fc1/22 2016547fee78f088
fc1/23 2017547fee78f088
fc1/24 2018547fee78f088
fc1/25 2019547fee78f088
enabled online F-port true 8 32 2100001086609c06
fc1/26 201a547fee78f088
fc1/27 201b547fee78f088
enabled online F-port true 8 32 21000024ff48ea93
fc1/28 201c547fee78f088
enabled online F-port true 8 32 21000024ff48eacf
fc1/29 201d547fee78f088
enabled online F-port true 4 32 500a098101484340
fc1/30 201e547fee78f088
enabled online F-port true 4 32 500a09810147e700
fc1/31 201f547fee78f088
fc1/32 2020547fee78f088
fc1/33 2021547fee78f088
fc1/34 2022547fee78f088
fc1/35 2023547fee78f088
fc1/36 2024547fee78f088
fc1/37 2025547fee78f088
fc1/38 2026547fee78f088
fc1/39 2027547fee78f088
fc1/40 2028547fee78f088
fc1/41 2029547fee78f088
fc1/42 202a547fee78f088
fc1/43 202b547fee78f088
fc1/44 202c547fee78f088
fc1/45 202d547fee78f088
fc1/46 202e547fee78f088
fc1/47 202f547fee78f088
fc1/48 2030547fee78f088
enabled offline auto true 0 0
port-channel 1
2401547fee78f088
port-channel 2
2402547fee78f088
port-channel 3
2403547fee78f088
port-channel 4
2404547fee78f088
port-channel 5
2405547fee78f088
port-channel 6
2406547fee78f088
port-channel 7
2407547fee78f088
port-channel 8
2408547fee78f088
port-channel 9
2409547fee78f088
port-channel 10
240a547fee78f088
port-channel 11
240b547fee78f088
port-channel 12
240c547fee78f088
sup-fc0 enabled online unknown true 1 0
The following command displays power supply unit information about all back-end FC switches:
cluster::> system switch fibre-channel show -power
Vendor: Cisco
Errors: -
Last Update Time: 7/31/2014 14:41:49 -04:00
Power Supplies:
Power Supply Serial Number Status
300.00W 110v AC PAC15494TBZ normal
300.00W 110v AC PAC15494T4D normal
The following command displays san configuration (VSANs and Zones) information about all back-end FC switches:
cluster::> system switch fibre-channel show -san-config
Vendor: Cisco
Errors: -
VSAN Configuration:
Oper
VSAN ID Vsan Name Status Load Balancing isIOD
1 VSAN0001 up src-id-dest-id true
2 dpg_13_storage up src-id-dest-id-ox-id
true
3 dpg_13_fcvi down src-id-dest-id-ox-id
true
10 dpg_mcc_13_fab1_fcvi up src-id-dest-id true
20 dpg_mcc_13_fab1_storage up src-id-dest-id-ox-id
true
30 dpg_mcc_13_fab2_fcvi up src-id-dest-id true
40 VSAN0040 up src-id-dest-id true
70 dpg_mcc_14_fcvi up src-id-dest-id true
80 dpg_mcc_14_storage up src-id-dest-id-ox-id
true
110 dpg_mcc_15_fcvi up src-id-dest-id-ox-id
true
120 dpg_mcc_15_storage up src-id-dest-id-ox-id
true
4094 isolated_vsan down src-id-dest-id-ox-id
true
VSAN Membership:
VSAN ID Switch Name Switch Port Name
1 Cisco_10.226.197.34 fc1/2
1 Cisco_10.226.197.34 fc1/7
1 Cisco_10.226.197.34 fc1/8
1 Cisco_10.226.197.34 fc1/9
1 Cisco_10.226.197.34 fc1/10
1 Cisco_10.226.197.34 fc1/11
1 Cisco_10.226.197.34 fc1/12
1 Cisco_10.226.197.34 fc1/14
1 Cisco_10.226.197.34 fc1/19
1 Cisco_10.226.197.34 fc1/20
1 Cisco_10.226.197.34 fc1/21
1 Cisco_10.226.197.34 fc1/22
1 Cisco_10.226.197.34 fc1/23
1 Cisco_10.226.197.34 fc1/24
1 Cisco_10.226.197.34 fc1/31
1 Cisco_10.226.197.34 fc1/32
1 Cisco_10.226.197.34 fc1/33
1 Cisco_10.226.197.34 fc1/34
1 Cisco_10.226.197.34 fc1/35
1 Cisco_10.226.197.34 fc1/36
1 Cisco_10.226.197.34 fc1/37
1 Cisco_10.226.197.34 fc1/38
1 Cisco_10.226.197.34 fc1/39
1 Cisco_10.226.197.34 fc1/40
1 Cisco_10.226.197.34 fc1/41
1 Cisco_10.226.197.34 fc1/42
1 Cisco_10.226.197.34 fc1/43
1 Cisco_10.226.197.34 fc1/44
1 Cisco_10.226.197.34 fc1/45
1 Cisco_10.226.197.34 fc1/46
1 Cisco_10.226.197.34 fc1/47
1 Cisco_10.226.197.34 fc1/48
1 Cisco_10.226.197.34 port-channel 1
1 Cisco_10.226.197.34 port-channel 2
1 Cisco_10.226.197.34 port-channel 3
1 Cisco_10.226.197.34 port-channel 4
1 Cisco_10.226.197.34 port-channel 5
1 Cisco_10.226.197.34 port-channel 6
1 Cisco_10.226.197.34 port-channel 7
1 Cisco_10.226.197.34 port-channel 8
1 Cisco_10.226.197.34 port-channel 9
1 Cisco_10.226.197.34 port-channel 10
1 Cisco_10.226.197.34 port-channel 11
1 Cisco_10.226.197.34 port-channel 12
1 Cisco_10.226.197.36 fc1/2
1 Cisco_10.226.197.36 fc1/7
1 Cisco_10.226.197.36 fc1/8
1 Cisco_10.226.197.36 fc1/9
1 Cisco_10.226.197.36 fc1/10
1 Cisco_10.226.197.36 fc1/11
1 Cisco_10.226.197.36 fc1/12
1 Cisco_10.226.197.36 fc1/14
1 Cisco_10.226.197.36 fc1/19
1 Cisco_10.226.197.36 fc1/20
1 Cisco_10.226.197.36 fc1/21
1 Cisco_10.226.197.36 fc1/22
1 Cisco_10.226.197.36 fc1/23
1 Cisco_10.226.197.36 fc1/24
1 Cisco_10.226.197.36 fc1/26
1 Cisco_10.226.197.36 fc1/31
1 Cisco_10.226.197.36 fc1/32
1 Cisco_10.226.197.36 fc1/33
1 Cisco_10.226.197.36 fc1/34
1 Cisco_10.226.197.36 fc1/35
1 Cisco_10.226.197.36 fc1/36
1 Cisco_10.226.197.36 fc1/37
1 Cisco_10.226.197.36 fc1/38
1 Cisco_10.226.197.36 fc1/39
1 Cisco_10.226.197.36 fc1/40
1 Cisco_10.226.197.36 fc1/41
1 Cisco_10.226.197.36 fc1/42
1 Cisco_10.226.197.36 fc1/43
1 Cisco_10.226.197.36 fc1/44
1 Cisco_10.226.197.36 fc1/45
1 Cisco_10.226.197.36 fc1/46
1 Cisco_10.226.197.36 fc1/47
1 Cisco_10.226.197.36 fc1/48
30 Cisco_10.226.197.34 fc1/3
30 Cisco_10.226.197.34 fc1/4
30 Cisco_10.226.197.36 fc1/3
30 Cisco_10.226.197.36 fc1/4
40 Cisco_10.226.197.34 fc1/1
40 Cisco_10.226.197.34 fc1/5
40 Cisco_10.226.197.34 fc1/6
40 Cisco_10.226.197.36 fc1/1
40 Cisco_10.226.197.36 fc1/5
40 Cisco_10.226.197.36 fc1/6
70 Cisco_10.226.197.34 fc1/15
70 Cisco_10.226.197.34 fc1/16
70 Cisco_10.226.197.36 fc1/15
70 Cisco_10.226.197.36 fc1/16
80 Cisco_10.226.197.34 fc1/13
80 Cisco_10.226.197.34 fc1/17
80 Cisco_10.226.197.34 fc1/18
80 Cisco_10.226.197.36 fc1/13
80 Cisco_10.226.197.36 fc1/17
80 Cisco_10.226.197.36 fc1/18
110 Cisco_10.226.197.34 fc1/26
110 Cisco_10.226.197.34 fc1/27
110 Cisco_10.226.197.34 fc1/28
120 Cisco_10.226.197.34 fc1/25
120 Cisco_10.226.197.34 fc1/29
120 Cisco_10.226.197.34 fc1/30
120 Cisco_10.226.197.36 fc1/25
120 Cisco_10.226.197.36 fc1/29
120 Cisco_10.226.197.36 fc1/30
Last Update Time: 7/31/2014 14:45:40 -04:00
Zone Configuration:
Member Member Member
Zone Name VSAN ID Switch Name Port Name Port ID Member WWN
dpg_mcc_fcvi 30 Cisco_10.226.197.36
fc1/3 -
$default_zone$ 30 Cisco_10.226.197.36
fc1/4
dpg_mcc_storage
fc1/1
$default_zone$ 40 Cisco_10.226.197.36
fc1/5
dpg_mcc_14_fcvi
fc1/15
$default_zone$ 70 Cisco_10.226.197.36
fc1/16
dpg_mcc_14_storage
fc1/13
$default_zone$ 80 Cisco_10.226.197.34
fc1/17
dpg_mcc_15_fcvi
110 Cisco_10.226.197.36
fc1/27
$default_zone$
fc1/28
dpg_mcc_15_storage
fc1/25
$default_zone$
fc1/29
The following command displays port SFP information about all back-end FC switches:
cluster::> system switch fibre-channel show -sfp
Vendor: Cisco
Errors: -
SFP:
Port Name Type Tx Type Vendor Part Number Serial Number
fc1/1 sfp-with-serial-id
short-wave-laser CISCO-FINISAR
FTLF8528P2BCV-CS
FNS160629J9
fc1/2 unknown unknown
fc1/3 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629H3
fc1/4 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629QH
fc1/5 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160628EA
fc1/6 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629QT
fc1/7 unknown unknown
fc1/8 unknown unknown
fc1/9 unknown unknown
fc1/10 unknown unknown
fc1/11 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629GP
fc1/12 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS16061X71
fc1/13 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629P8
fc1/14 unknown unknown
fc1/15 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629JP
fc1/16 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160628D2
fc1/17 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629NG
fc1/18 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629R1
fc1/19 unknown unknown
fc1/20 unknown unknown
fc1/21 unknown unknown
fc1/22 unknown unknown
fc1/23 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629NC
fc1/24 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160628CX
fc1/25 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629NZ
fc1/26 unknown unknown
fc1/27 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS16061XB0
fc1/28 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS16061XA6
fc1/29 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS16061XA0
fc1/30 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS16061X9S
fc1/31 unknown unknown
fc1/32 unknown unknown
fc1/33 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS16061NL7
fc1/34 unknown unknown
fc1/35 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629M8
fc1/36 sfp-with-serial-id
FTLF8528P2BCV-CS
FNS160629KH
fc1/37 unknown unknown
fc1/38 unknown unknown
fc1/39 unknown unknown
fc1/40 unknown unknown
fc1/41 unknown unknown
fc1/42 unknown unknown
fc1/43 unknown unknown
fc1/44 unknown unknown
fc1/45 unknown unknown
fc1/46 unknown unknown
fc1/47 unknown unknown
fc1/48 unknown unknown
port-channel 1
unknown unknown
port-channel 2
unknown unknown
port-channel 3
unknown unknown
port-channel 4
unknown unknown
port-channel 5
unknown unknown
port-channel 6
unknown unknown
port-channel 7
unknown unknown
port-channel 8
unknown unknown
port-channel 9
unknown unknown
port-channel 10
unknown unknown
port-channel 11
unknown unknown
port-channel 12
unknown unknown
sup-fc0
The following command displays port statistics information about all back-end FC switches:
cluster::> system switch fibre-channel show -stats
Vendor: Cisco
Errors: -
Port Statistics:
Rx Rx Tx Tx Error
Port Name Frames Octets Frames Octets Frames
fc1/1 2116207233 3710682580 3906335374 859905888 0
fc1/2 1 208 1 208 0
fc1/3 3238899002 903116292 3079548736 4014304952 0
fc1/4 1888758418 1643379900 2434821325 2997002344 0
fc1/5 3719731908 1808138824 1878240211 3421335100 0
fc1/6 2644430347 1042009564 249190625 2003353056 0
fc1/7 1 228 1 228 0
fc1/8 1 156 1 156 0
fc1/9 1 148 1 148 0
fc1/10 1 224 1 224 0
fc1/11 3617142898 4129927136 39089396 2595464620 0
fc1/12 473603889 1560909460 2797562521 2833496016 0
fc1/13 1852255936 1091902804 180309704 1769859928 0
fc1/14 1 140 1 140 0
fc1/15 4997082 3519688264 4283938 3370856432 0
fc1/16 4995287 3519577592 4282173 3370732136 0
fc1/17 55146756 178045212 1733567096 3030415436 0
fc1/18 63005788 4287094736 1726651844 2640371212 0
fc1/19 1 200 1 200 0
fc1/20 1 104 1 104 0
fc1/21 1 108 1 108 0
fc1/22 1 108 1 108 0
fc1/23 1 164 1 164 0
fc1/24 1 216 1 216 0
fc1/25 2810698819 1611009260 471527156 1900246656 0
fc1/26 1 104 1 104 0
fc1/27 4165019838 887421780 3848122102 2581891136 0
fc1/28 58607737 1015197080 101621078 3482734024 0
fc1/29 4266270960 222242144 3766674764 2400640552 0
fc1/30 3984658378 1443835508 152597387 678837848 0
fc1/31 1 220 1 220 0
fc1/32 1 120 1 120 0
fc1/33 1 132 1 132 0
fc1/34 1 144 1 144 0
fc1/35 1 160 1 160 0
fc1/36 1 104 1 104 0
fc1/37 1 148 1 148 0
fc1/38 1 184 1 184 0
fc1/39 1 160 1 160 0
fc1/40 1 136 1 136 0
fc1/41 1 196 1 196 0
fc1/42 1 128 1 128 0
fc1/43 1 168 1 168 0
fc1/44 1 212 1 212 0
fc1/45 1 136 1 136 0
fc1/46 1 224 1 224 0
fc1/47 1 104 1 104 0
fc1/48 1 104 1 104 0
